Unknown carburetor
this thread has 5 replies and has been viewed 595 times
Old 02-22-2019, 09:56:58 PM
Hitmiss635 Hitmiss635 is offline
Default Unknown carburetor
I have no idea what this carburetor is it was attached to a model 92 Maytag that I got for free it looks like it was retrofitted onto the engine any help on this would be great!
ID:	329224   Click image for larger version
ID:	329225   Click image for larger version
Old 02-22-2019, 10:57:33 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Default Re: Unknown carburetor
I can't recall what make the carb is, but they were used on the larger Brigg and Stratton engines. We had one on our Suburban 725 garden tractor. 7.25 hp Briggs engine
Old 02-22-2019, 11:37:39 PM
GADavis GADavis is offline
B&S flow jet 2 piece unit carburetor.
Old 02-23-2019, 12:42:22 AM
Bob Shannon Bob Shannon is offline
Briggs for sure. Would like to see that in action!
Old 02-23-2019, 01:08:18 AM
K-Tron K-Tron is offline
More specifically it is a small flojet, as indicated by the four perimeter screws which fasten both halves of the carburetor together. The larger flojets have three screws in triangular orientation. These carburetors were used on a lot of the small number series Briggs. I have them on cast iron model 8's and 9's
Old 02-23-2019, 01:30:38 PM
Exclamation Re: Unknown carburetor
My grandfather had an early rotary lawnmower with an aluminum block B&S engine on it. A number 6 type I think. Your carb is indeed a Flo-Jet, and it looks just like the one from that early mower - circa 1959. I should know, I 'helped' grandpa 'fix it' when i was only 5 years old. He had bent the blade and left a vice grip, hammer and stevens screw driver next to the mower, and then I went to work. i still have that like new carb, the only part taken off intact. The mount plate looks home made.
How did they mount the carb on the Maytag? Where did they mount the fuel tank? Flo-Jets are gravity fed carbs. Did they use the original Maytag poppet valve in the original mixer, or some kind of reed to keep crankcase pressure and vacuum contained? If the 'farmer fix' worked, someone did a cool job of it. Or was it a failed experiment? If there were no reeds or a check valve between the carb and the crankcase, it will not work.
Unknown Carburetor MiqC2001 Carburetors, Mixers, Fuel Pumps and fuel delivery 2 09-09-2018 08:54:10 PM
ID Unknown Carburetor? G.M.Johnson Small Air Cooled Gasoline Engines 6 02-08-2017 07:19:12 PM
Unknown Carburetor NAR Hit & Miss Gas Engine Discussion 2 05-08-2015 06:47:38 AM
unknown carburetor mokeabean Carburetors, Mixers, Fuel Pumps and fuel delivery 3 11-26-2014 05:49:49 PM
Unknown Carburetor signalman Hit & Miss Gas Engine Discussion 10 03-09-2010 01:27:38 AM
