Associated/Stover Engine Cart replacement part
this thread has 9 replies and has been viewed 929 times
Old 10-14-2019, 12:30:53 AM
Jeff Holbrook Jeff Holbrook is offline
Default Associated/Stover Engine Cart replacement part
I have a engine cart I believe to be a Associated or a Stover engine cart. Can anyone identify the cart for sure? As you can see the front mount is in very poor condition! I need to replace it with a new piece. I am wondering if the tubular steel is the original or should it have something else? If anyone has a picture, I sure would appreciate it!! Thanks in advance!! Jeff
ID:	346473   Click image for larger version
ID:	346474   Click image for larger version
Old 10-14-2019, 08:45:53 AM
hitmis1's Avatar
hitmis1 hitmis1 is offline
Default Re: Associated/Stover Engine Cart (replacement par)t
Hi Jeff,
It is Associated and the tube steel is correct.
Bill in KY
The Following User Says Thank You to hitmis1 For This Post:
Old 10-14-2019, 10:03:36 AM
OrgWayne OrgWayne is offline
Hay Jeff any snow flakes yet ?? the Stover Cart is for a larger then 2 Hp Engine Correct ? I Have a 2 HP CT-2/TB 1936 ,I have never seen a cart for the smaller engines even on Stack, on here some where I'M sure
Wayne
The Following User Says Thank You to OrgWayne For This Post:
Old 10-30-2019, 10:27:56 PM
Yes Wayne the snow is starting to land!! Looks like I'll be replacing the back axle channels also!! That's a lot of drilling!! I'm very surprised at the severe rust out on this cart, but only in certain places!!
ID:	347957   Click image for larger version
ID:	347958   Click image for larger version
Old 11-01-2019, 02:55:04 PM
Default Re: Associated/Stover Engine Cart replacement part
New parts!! A lot of drilling!!!!
ID:	348065   Click image for larger version
Old 11-02-2019, 04:33:56 PM
You can see why it needed to be replaced!! Got it done today!!
ID:	348154   Click image for larger version
ID:	348155   Click image for larger version
The Following User Says Thank You to Jeff Holbrook For This Post:
Old 11-03-2019, 08:56:55 PM
Matthew Guy Clarke Matthew Guy Clarke is offline
I think this cart is from a Sandwich corn sheller. A Waterloo is similar but I have 2 like it. Hub pictures would be more determining.
The Following User Says Thank You to Matthew Guy Clarke For This Post:
Old 11-13-2019, 06:23:45 PM
Hello Matt: Here is a picture of the hub and the new rear axle. Let me know what you think? Thanks, Jeff
ID:	348976   Click image for larger version
Old 11-13-2019, 07:43:03 PM
Kevin O. Pulver Kevin O. Pulver is offline
Email NOT Working
You're doing a great job Jeff!
Believe it or not, I replaced a section of inch and a quarter gas line that looked almost just that bad
It wasn't buried but it was laying in the bottom of a ditch on its way to an irrigation motor. I think the grass and dirt that had built up on top of it was all that was holding in the gas to keep it running!
The Following User Says Thank You to Kevin O. Pulver For This Post:
Old 11-15-2019, 11:31:35 AM
It may be a Associated, but it hence forth a Stover cart!! LOL!!
The Following 2 Users Say Thank You to Jeff Holbrook For This Post:
Rock Island Gas Engine Cart Part Gary Biewer Hit & Miss Gas Engine Discussion 0 06-10-2016 06:01:04 PM
Replacement part information LWCash Hit & Miss Gas Engine Discussion 0 04-08-2012 09:19:12 PM
Wico EK replacement part 2 Mark Birdeau Hit & Miss Gas Engine Discussion 14 11-14-2009 11:23:22 AM
Need a picture of original Stover CT1 engine cart Robert DeBord Hit & Miss Gas Engine Discussion 0 04-05-2009 11:42:26 AM
Replacement part info Steve G Onan Generators 2 02-07-2006 12:44:47 PM
