Straightening connecting rods
this thread has 9 replies and has been viewed 1012 times
Old 10-07-2019, 12:09:05 PM
Russ Hamm's Avatar
Default Straightening connecting rods
I found a couple of mentions of straightening connecting rods in a thread search here, but nothing really definite except for where a member had 10-20 Titan rods straightened. I found one place that said they could straighten it, otherwise I think rather than doing it myself in the press they probably have the experience more so. I remember, I think, that you have to bend it past straight the other direction and then back to straight, not sure how much is best.
Old 10-07-2019, 12:24:53 PM
Default Re: Straightening connecting rods
It is just trail and error. You will end up going too far at one point, then have to bend back.
Old 10-07-2019, 01:11:33 PM
LCJudge LCJudge is offline
I've straighten rods on two different engines. One was rather small, 4 HP, but the other was larger about 10 HP. On both engines they had been converted to wood splitters with wedges bolted to the piston. I'm sure both were bent due to the severe blows inflicted on the rod. I borrowed a friends large vernier caliper (it went to 48") and as Bill said, it was trial and error in the press. The vernier caliper measured the parallel surfaces of the wrist pin end and rod end of the connecting rod. I also used a surface block and squares to ensure I got them parallel in all respects. I got them to within about a thousandth and said good enough! I knew if I tried to take that out I'd probably go too far and then be pressing in the opposite direction.
Tommy Turner
The Following 5 Users Say Thank You to LCJudge For This Post:
Old 10-07-2019, 06:23:55 PM
That might be this thread >>> https://www.smokstak.com/forum/showt...=68254&page=11
Pick it up at post 209.
Old 10-07-2019, 06:46:40 PM
ronm ronm is offline
The only way to get them perfect is to line bore an undersize bushing in the pin end to size on a rod machine or set up on a mill parallel to the big end bore. That said, +/- a thou is most likely good enough for a hit & miss...
A lot of rods that come out of an engine are not exactly straight. Line boring compensates for the bend, my old machinist friend didn't like factory John Deere rod bushings because they didn't leave enough meat in them to always clean up...
Smokstak member #442
The Following User Says Thank You to ronm For This Post:
Old 10-18-2019, 12:22:18 PM
Russ Hamm's Avatar
Well, as I had not heard from the machine shop I decided to try and switch rod bearings, see how I could re-rivet them in with the copper rivets. I haven't found 1/4" countersunk rivets yet but thought about making some. Called to see about picking up the rod and found out they straightened it, BUT, they had to heat it to get it there.
I am skeptical about heating just the end, what do you all think?
Old 10-18-2019, 12:39:47 PM
Not sure why they had to heat it, 10 or 15 tons should be enough for you garden variety tractor connecting rod. It will probably fine fine though.
Old 10-19-2019, 10:03:47 AM
windmillman windmillman is offline
Those 1/4 copper rivets with countersunk head are used on wood pump rod couplings on windmills for the larger size hexagon wood rod. Maybe try a windmill repair man in your area.
Old 10-19-2019, 12:06:26 PM
Barnbikes Barnbikes is offline
Will brass work.
https://www.grainger.com/search?sear...y=rivets+brass
Old 10-19-2019, 05:38:40 PM
Glenn Ayers Glenn Ayers is offline
It's common practice in the automotive industry to heat the rod small end for the "press fit" wrist pins. You heat them up in a special "Rod Oven" .. then slip the wrist pin thru the piston & into the rod & hold it in place side to side. It cools momentarily & locks the pin in place.
"I'll have the Red Pill, thank you."
Help identify old GM connecting rods Jeff Blaney Antique Autos and Trucks 5 09-16-2012 06:44:05 AM
Connecting Rods Jack Innes Antique Farm Tractors 6 10-07-2011 09:23:32 PM
Connecting Rods Jack Innes Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 10-06-2011 10:48:04 PM
Leroi 201,226 connecting rods bcpuller Hit & Miss Gas Engine Discussion 2 09-01-2010 10:21:03 AM
Can Anyone ID These Bronze Connecting Rods? Chris Lewis Hit & Miss Gas Engine Discussion 5 01-19-2008 07:26:17 PM
