Zenith TX4 problems.
this thread has 4 replies and has been viewed 237 times
Old 10-15-2019, 08:55:40 PM
Brian Lynch's Avatar
Brian Lynch Brian Lynch is offline
Default Zenith TX4 problems.
Hi All, I've a problem child on my hands. A New Way model CH 5HP engine with a Zenith TX4 carb. This carb will not leak a drop when the needle and seat make contact in the float bowl. As soon as it is started the carb drools fuel out of the bottom and it runs rich. All the jets are correct and tight. The float is about as perfect as one can get. Needle and seat work great. Are these carbs that sensitive to vibration? It has a cast iron throttle body. The typical expanding pot metal venturi crack is present and has been dealt with, so that's not an issue. The carb looks good inside. What am I missing here?
"May your walk through life have no dogpiles in it" -Brian Lynch
Old 10-18-2019, 05:36:23 PM
Default Re: Zenith TX4 problems.
Never mind, we solved the problem.
Old 10-18-2019, 09:47:15 PM
what did y'all find?
Old 10-18-2019, 11:13:47 PM
Hooked it up to natural gas and it ran fine. Jets had been drilled out for NG. Changed jets and it runs fine on gasoline.
The Following 2 Users Say Thank You to Brian Lynch For This Post:
Old 10-19-2019, 09:12:56 PM
ulgydog56's Avatar
Zenith K5 BillMN Carburetors, Mixers, Fuel Pumps and fuel delivery 2 06-19-2018 05:12:21 PM
Zenith TS4 joder Carburetors, Mixers, Fuel Pumps and fuel delivery 5 11-19-2016 07:15:02 PM
Zenith Carb John Deck Carburetors, Mixers, Fuel Pumps and fuel delivery 1 09-30-2016 09:35:32 PM
Help with Zenith K5 KevinGWeq Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 08-28-2013 03:52:38 PM
zenith carb? mean Wisconsin Engines 3 04-29-2013 12:44:46 PM
