About Capacitors
this thread has 20 replies and has been viewed 26201 times
Closed Thread
Old 11-27-2002, 08:54:53 PM
Ralph Leonard
Default Re: About Capacitors
Hi everyone,
I would like to expand on Russ's mention of high tension ignition. When the points open the capacitor is connected in series with the coil.
The voltage/current generated by the colapsing magnetic field charges the capacitor. This is the voltage/current source that is induced into the stepped up secondary winding.
A coil opposes current flow while a capacitor enhances current flow.
The enhancement of the capacitor balances out or cancels the opposition of the coil.
The result is a faster colapse of the magnetic field and the highest posible voltage generated in the primary ckt.
It's true that the capacitor reduces or prevents arcing at the points but it's main function is to provide a ckt path for the coil after the points open and to speed up the colapse of the magnetic field. Hope this helps a little, Ralph in NC
http://www.smokstak.com/forum/showthread.php?t=21175
Closed Thread
Question about Capacitors Chris Schmidt Generators & Electric Motors General Discussion 22 01-21-2012 02:24:52 AM
Brush Capacitors Mark99 Onan Generators 12 12-06-2010 01:17:38 AM
Onan W3/W2 Points & Capacitors ListerDiesel Onan Generators 0 09-06-2010 01:57:58 PM
Capacitors / Condensers mowersman Magnetos, Ignition Coils and Spark Plugs 10 05-15-2010 02:23:26 PM
Replacement Capacitors? Mikey4026 Generators & Electric Motors General Discussion 7 01-22-2009 02:28:36 PM
