Go Back   SmokStak > SmokStak® General Off Topic Discussion > Antique Autos and Trucks
IH Silver Diamond Verses Black Diamond Engine
this thread has 6 replies and has been viewed 8695 times
Old 01-26-2013, 10:31:32 PM
Gary Pflum's Avatar
Gary Pflum Gary Pflum is offline
Default IH Silver Diamond Verses Black Diamond Engine
Please refresh my memory. If I take a BD240 (Black Diamond) out of an IH truck, will a SD220 (Silver Diamond) bolt up the same?
Old 01-28-2013, 12:31:28 AM
vern0n's Avatar
vern0n vern0n is offline
Default Re: IH Silver Diamond Verses Black Diamond Engine
Yeap. They are basically the same.
---------- Post added at 10:31 PM ---------- Previous post was at 10:29 PM ----------
You can also go with the BG series engines which have the better head.
The Following User Says Thank You to vern0n For This Post:
Old 01-28-2013, 10:35:12 AM
Gary Pflum's Avatar
Thanks. That's what I thought but I wanted to be sure before the swap begins.
Old 01-30-2013, 03:16:17 PM
John Hamilton's Avatar
John Hamilton John Hamilton is offline
Except the SD 220 is 220 cubic inches and the BD 240 is larger.
The Following User Says Thank You to John Hamilton For This Post:
Old 02-05-2013, 03:51:10 PM
Exclamation Re: IH Silver Diamond Verses Black Diamond Engine
The SD also has poured bearings. If you plan to use at highway speeds, a more modern engine might be in order. When used in the L series trucks (110 & 120 '49 to '52), 45 MPH tops! Late '52 to '55, you would get 50 MPH out of them, until the internal resonant vibrations broke the exhaust valves. The later GD series '55 and later), was a better engine - modern bearings and an updated valve train.
Old 02-06-2013, 01:10:49 AM
vern0n's Avatar
Are you sure the SD has poured bearings? The Green Diamond has inserts and it predates the Silver diamond. Here is a web site with great info.
http://www.binderplanet.com/forums/s...ad.php?t=45980
Old 02-06-2013, 12:19:11 PM
Gary Pflum's Avatar
I checked out the Binder web site. It does have good info. We have a 1956 S-130 with a bad BD240. We located a 1953 R 130 with a good SD 220 engine for the swap. We are going to leave the truck in it's barn clothes and just use it for short runs.
IHC. Super Black Diamond BD282.. positive ID ? diesel543 Antique Autos and Trucks 7 02-03-2011 02:30:41 PM
Diamond toolholder Craig M. Strader Sr. Machine Shop and Tool Talk 3 10-17-2009 09:35:28 PM
1945 Red Diamond IH engine ad Delta Dirt Antique Autos and Trucks 5 11-21-2006 08:12:33 PM
Diamond Valve? BMiller Hit & Miss Gas Engine Discussion 1 10-01-2006 11:03:21 AM
Black Diamond Machine company William Rogers Antique Engine Archives 0 05-09-2004 10:00:20 PM
