Sattley, Field Brundage what can you tell me?
this thread has 9 replies and has been viewed 2379 times
Old 08-06-2013, 07:50:50 PM
Will Batty's Avatar
Will Batty Will Batty is offline
Default Sattley, Field Brundage what can you tell me?
Looking for any info that I can get on these two engines that I picked up at an auction last week. the governor intrigued me so I bought two engines There is no tag that I can find, does not look like there ever was tag and I have not been able to locate a serial number. Should these engines have a tag? I have assumed that they both are 1-1/2 hp. engines. Bore is 3-1/2" flywheels are 19" diameter. How does the governor work, do you just slide the collar in and out. One engine is stuck and the other is loose but the collar is stuck on both engines. you do not come across these engines up here in my neck of the woods so any info is appreciated!
Name:	Porth auction engines 003.JPG
ID:	171659   Click image for larger version
Name:	Porth auction engines 004.JPG
ID:	171660   Click image for larger version
Name:	Porth auction engines 005.JPG
ID:	171661   Click image for larger version
Name:	Porth auction engines 006.JPG
Old 08-06-2013, 09:15:16 PM
Doug Kimball's Avatar
Default Re: Sattley, Field Brundage what can you tell me?
Will,
Try this site: https://sites.google.com/site/packrat56/pnfbahome
The 1 1/2 hp was available throttle governed or hit & miss like yours. The collar gives three speeds.
In Kennebunk, Maine;
Doug Kimball
The Following User Says Thank You to Doug Kimball For This Post:
Old 08-06-2013, 09:38:44 PM
Martin Gaudet Martin Gaudet is offline
My dad comes from near Batoche. If you ever get down to Saskatoon, check out the pioneer museum. They have all of the machinery there with which they opened the prairies with. I got lots of stories first hand from him and my uncles.
Cheers!
Martin Gaudet
The Following User Says Thank You to Martin Gaudet For This Post:
Old 08-07-2013, 09:37:47 AM
Will Batty's Avatar
Martin I have been to the Western Development Museum in Saskatoon quite a few times now. I did not go to their Pion-Era show this summer, as it was raining on the Saturday. I would like to tour their back room/storage area as I think they have a lot of gems not on display. The WDM in North Battleford and Yorkton also have some nice pieces. Never have made it to the WDM in Moose Jaw, my travels never seem to take me there?
Old 08-07-2013, 01:11:55 PM
wlb wlb is offline
I can tell you to be careful with the sliding collar, most I have seen are chipped or missing. The one I have the collar comes off of the crank shaft pretty easy and could hit the ground an become many small chunks of collar. Nice engine!
The Following User Says Thank You to wlb For This Post:
Old 04-15-2016, 12:36:57 AM
greenmars2 greenmars2 is offline
Did you ever get either of the field brundage engines running?
I just recently acquired one myself and am just getting started in this hobby.
Old 04-15-2016, 10:17:08 AM
Will Batty's Avatar
The only thing I have done was go through the Mag bracket and tried it on another Field & Brundage engine I have. I need to finish up some engine projects before starting another one! I have too many projects not enough time which is not a bad thing.
Old 04-17-2016, 05:13:12 PM
newway1978 newway1978 is offline
hello will i picked up one of thies engines last summer the one i have is taged
mc clouds but iam missing some of the gov assy
Old 01-28-2019, 09:21:03 AM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Originally Posted by Will Batty View Post
Looking for any info that I can get on these two engines that I picked up at an auction last week. the governor intrigued me so I bought two engines There is no tag that I can find, does not look like there ever was tag and I have not been able to locate a serial number. Should these engines have a tag? !
Hi Will, have you checked the number on the Webster bracket for this engine? That number would be an indication as to if the engine was built by Field-Brundage or not.
Denis Rouleau
Old 01-30-2019, 09:54:00 AM
Will Batty's Avatar
Denis, the g umbers from the bracket was the same as a Field Brundage.
Looking for some Sattley (Field-Brundage) dimensions and numbers Craig Solomonson Hit & Miss Gas Engine Discussion 1 03-28-2013 08:59:46 PM
Field Brundage Racene Sattley startup Mike King Hit & Miss Gas Engine Discussion 8 01-09-2012 08:29:41 PM
Indentifying a Field Brundage / Sattley Harry Hit & Miss Gas Engine Discussion 9 08-07-2008 02:17:36 PM
need 1 1/2 hp field brundage value... JBoogie Hit & Miss Gas Engine Discussion 0 09-17-2006 11:38:23 AM
Magneto for a 5 HP Macleod or Sattley as built by Field Brundage spfx_dude Magnetos, Ignition Coils and Spark Plugs 2 07-03-2006 10:26:52 PM
