kohler K91t ignition problems
this thread has 1 replies and has been viewed 1459 times
Old 06-20-2015, 09:29:03 AM
James Wallace James Wallace is offline
Default kohler K91t ignition problems
Working on a kohler k91t. Replaced the coil, points & condenser. No spark. Cleaned points several times, saw 1 weak blue spark then no luck. Getting 5.4 ohms from each side of the coil, could be too high. Any suggestions appreciated.
Old 06-20-2015, 02:48:15 PM
Default Re: kohler K91t ignition problems
I'm kind of suspecting the replacement condenser is weak. The lead wire tests the same for ohms as the coil tests when the leads off. Magnets on the flywheel pass the screwdriver test. Found a dent in the side of the condenser. Just your typical possessed engine...
Briggs Kicker NS & "New" Kohler K91T Nevr-Enuf-Stuf Small Air Cooled Gasoline Engines 2 07-25-2013 11:57:11 PM
More ignition problems 7.5 JB papatony Onan Generators 19 11-19-2010 10:19:21 PM
Ignition problems Slow Roller Hit & Miss Gas Engine Discussion 6 11-28-2009 10:50:39 AM
Kohler K91T carb settings fastball68 Small Air Cooled Gasoline Engines 7 03-13-2006 02:18:13 PM
ignition coil problems?? jim king Antique Engine Archives 4 10-02-2003 01:46:59 AM
