Restoration of the Rumely 6 (40 Posts so far)
this thread has 52 replies and has been viewed 8030 times
Old 06-29-2019, 09:09:41 AM
Wayne Riedlinger Wayne Riedlinger is offline
Default Re: Restoration of the Rumely 6 (40 Posts so far)
That clutch looks almost identical to the clutch in our Wallis tractor. it is a twin disk too.
Old 07-02-2019, 09:23:32 AM
Rumely6a Rumely6a is offline
New question about main bearing fit specifically thrust bearing
the Wauk 6MZ has std 2 5/8 main bearings (bearing catalog says also 2 3/4 but all mine are 2 5/8). The machine shop doing the work says the bearings fit reasonably (some with 0.040 to 0.080 shims) except the thrust which has a much higher gap for the most part - requiring maybe as much as 0.200 in shims! they are nervous about this worried the specified bearings are the wrong bearing for the thrust bearing only? their solution stick with the bearings removed from that block specifically (which mean rebabitt). The cap side seems to fit better with "normal" shim requirements.
I will measure the height of each thrust bearing half (I have a number of engines and bearing sets) to see if there is a variance among them - if there is it suggest the bearing heights would have been shortened over time - was that customary?
attached is a photo of the block journal - this one used thrust washers (note the roll pin). Some of the bearing sets have flanged thrust surfaces and some have the separate thrust washers (newer)
What are we missing here? Could the face of the journal been machined over the years (does not look like it)? Could the bearing height have been machined as the bearing wore and the backer brass was added to take up wear (some blocks had backer brass strips behind the each bearing but very thin 010 or 020)? what was customary to refit for wear in the old days? the wauk service manual gives a general description of this fitting but mostly say leave it to the experts...
The Following User Says Thank You to Rumely6a For This Post:
  #43
Old 07-04-2019, 11:32:48 AM
getting to the last details of the restoration - metal tag -
any suggestions where I could have these made - I think Aluminum?
Old 07-09-2019, 11:28:09 PM
Rob Gill from KY makes custom tags for old engines, etc. He could probably make you one.
Mike
The Following 2 Users Say Thank You to Mike McKnight For This Post:
  #45
Old 07-14-2019, 07:01:44 AM
some more progress on the Rumely 6 "fleet"
Tractor no1 should be completed SOON!!!!! photos to follow
Engine no2 on the hook and ready to go back on the tractor
Engine no3 in final assembly in the machine shop - including new aftermarket 060 pistons no sleeves. These pistons were patterned after original std sized pistons (4 1/4). This tractor will remain "original" unrestored as the sheet metal was well taken care of by the previous owners
engine no4 still in weld shop for crack repairs to the block- lots of cracks and unfortunately a low priority for the shop
attached is a photo of Engine no 2 on the hook - note the Allis Chalmers Orange. this is the tractor my family farmed with into the early 60's and I was old enough to carry gas cans to the field - plan to have that one orange. the rest of my 6's were all green and the green is still prominent under the orange paint. oh the good old days of lead based paint!
ok back to work!
The Following 8 Users Say Thank You to Rumely6a For This Post:
  #46
Old 07-15-2019, 09:10:24 PM
and on the tractor
The Following 3 Users Say Thank You to Rumely6a For This Post:
  #47
Old 07-18-2019, 08:48:15 AM
Now with head installed. Used a spray copper product to prep the head gasket - sure is more simple then the paint brush. Note spin on style oil filter - another innovation to improve the engine especially for a run in period. Can go back to the canister style which has been extensively discussed in some other threads
next - the carb and gear cover plate - and then fire it up!
  #48
Old 07-23-2019, 05:59:49 AM
First coat on Rumely #1 - Brewster Green (Dupont paint)
The Following 5 Users Say Thank You to Rumely6a For This Post:
  #49
Old 08-09-2019, 06:48:25 AM
ok back at the Rumely project this week. Picked up engine #3 from machine shop - looks great. As mentioned earlier new pistons 060 over no sleeves. There is quite a contrast between modern piston and the standard cast iron 4 ring. I will be interested in checking compression between the various engines - as I have new rings but re-used pistons on engine #2.
The Following 2 Users Say Thank You to Rumely6a For This Post:
  #50
Old 08-18-2019, 07:42:34 AM
Rumely #2 operational and ready for the restoration shop
notice the temporary fuel tank - hopefully that is large enough to get the beast on the trailer as it sure is thirsty
  #51
Old 09-25-2019, 10:57:57 AM
for you Rumely 6 guys out there the manuals and literature I have found for this model is as follows
- two nice brochures from the Wauk historical society describing the 6MZ engine in various configurations (no photos contact WEHS)
-the original operating manual
- a very detailed bulletin put out by the US Army detailing the (later version) of the engine - including demolition!
- general instructions for Wauk flathead engines - some unique info like bearing fitting
- a detailed parts catalog for the 6M from Waukesha - later versions of the engine
- repair price list of ALL parts that went into the tractor
ID:	345027   Click image for larger version
ID:	345028   Click image for larger version
ID:	345029   Click image for larger version
  #52
Old 09-25-2019, 10:59:15 AM
last photo
  #53
Old 10-23-2019, 07:45:34 AM
Rumely 6 - number 3 nearing reassembly with rebuilt block
Rumely E Mechanical Restoration LukeSte Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 90 09-03-2019 01:04:18 PM
Rumely 2040 G Restoration LukeSte Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 67 08-05-2019 09:45:06 AM
Restoration of 2 Rumely F's 19-65Port Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 18 09-22-2017 07:56:12 PM
Rumely 12-20 Restoration LukeSte Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 140 10-11-2015 10:58:44 PM
Rumely 25-40X Restoration, need parts Exmax Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 08-07-2010 06:11:34 PM
