Magneto charger magnetizer
this thread has 20 replies and has been viewed 2544 times
Old 03-29-2019, 09:34:48 PM
landreo landreo is offline
Default Re: Magneto charger magnetizer
Some folks panic if the output of the magneto/spark coil is not negative polarity on the spark plug center terminal. There are some theoretical advantages but in the real world it does not matter. There should be at least a 100 % overhead for a decent coil. In other words, if the plug needs 10k volts to initiate a spark then the coil should be able to produce 20k volts. Switching the polarity will increase the needed voltage to initiate a spark to around 30% so that 10k volts becomes 13k volts but the coil can still produce 20k volts, much more than is needed.
As barry ayres stated, most magnetos switch polarity each 180 degrees of rotor rotation. Some, the Wico EK as an example and some single cylinder rotary magnetos, do not switch polarity. However, you have to polarize the magneto magnets somehow so for the uni polar magnetos, Wico EK etc.., you might as well polarize the magnets correctly.
Magneto Charger Geist Magnetos, Ignition Coils and Spark Plugs 2 06-22-2016 01:49:32 PM
Magneto magnetizer Neil Mactavish Smokstak Down Under 15 04-01-2014 09:59:45 PM
Magneto Charger Greg-N-CA Hit & Miss Gas Engine Discussion 2 11-05-2010 10:48:06 PM
Magneto Charger mccormick98 Magnetos, Ignition Coils and Spark Plugs 5 02-14-2010 11:10:14 PM
Rex's Magneto Charger Walt Beeman Hit & Miss Gas Engine Discussion 5 05-18-2009 09:59:59 AM
