Briggs and Stratton WMB converting it to run on Propane
this thread has 0 replies and has been viewed 456 times
Old 03-10-2019, 08:35:06 AM
tch50 tch50 is offline
Default Briggs and Stratton WMB converting it to run on Propane
I have a Briggs WMB and am contemplating converting it to run on propane. I have found drawings to make a demand regulator using Tecumseh parts. I think I can use the existing suction carburetor, but of course I would have to re-jet it. Rebuild kits are available for this carb, so I could get a new jet and bore it out. I could also install a larger needle in the brass needle body. My question is; is there a rule of thumb regarding how much to enlarge the jet? Also, if there is a rule of thumb for enlargement that is expressed as a percentage, would that be percentage of jet orifice diameter? Or percentage of orifice area? Thanks.
Converting a Briggs to Propane? enginesilo Small Air Cooled Gasoline Engines 5 06-10-2016 08:37:06 AM
Converting to Propane Ron Haskell Kohler Generators 5 10-08-2015 09:30:58 PM
Converting to propane.. deanrantala Onan Generators 11 01-16-2014 05:37:00 AM
converting to propane John Drabik Antique Engine Archives 6 09-05-2004 02:16:46 AM
Converting to propane Randy Ackley Antique Engine Archives 6 08-07-2000 03:10:00 AM
