1958 Minneapolis Moline 335 industrial, What kind of loader is this?
this thread has 10 replies and has been viewed 903 times
Old 07-16-2019, 11:26:52 PM
Default 1958 Minneapolis Moline 335 industrial, What kind of loader is this?
Hello all,
I have been using an industrial MM 335 around the acreage and it appears to be somewhat unusual. There were only 746 made and this one has power steering and a very heavy duty loader that I have not been able to identify. I have googled it with no luck so far. I hope someone here can tell me what brand this loader is. Thanks for any help and good luck on all your projects!
Tony
Name:	1958 MM 335 Industrial 746 made 002.jpg
ID:	339225   Click image for larger version
Name:	1958 MM 335 Industrial 746 made 006.jpg
ID:	339226   Click image for larger version
Name:	1958 MM 335 Industrial 746 made 010.jpg
ID:	339227   Click image for larger version
Name:	1958 MM 335 Industrial 746 made 014.jpg
ID:	339228   Click image for larger version
Name:	1958 MM 335 Industrial 746 made 013.jpg
The Following 3 Users Say Thank You to Tony Thompson For This Post:
Old 07-16-2019, 11:57:45 PM
Default Re: 1958 Minneapolis Moline 335 industrial, What kind of loader is this?
Looks like a MM model S 43?
Old 07-17-2019, 01:08:14 AM
Jim Anderson's Avatar
Jim Anderson Jim Anderson is offline
Nice clean looking little minny mo you got there Tony!
The Following User Says Thank You to Jim Anderson For This Post:
Old 07-17-2019, 08:58:27 AM
Case R,
As I stated in my first post, I have been re-searching this loader with no ID so far. MM S-43 is a very good loader, but does not look like mine. My photos show more of a "Lull" or "Ottawa" industrial type unit.
Also note the long pipe arm and pivot on bucket cylinders...a kind of self leveling system for bucket.
Massive under-mount uses "pyramid" uprights that dual as fluid reservoir.
Here is the S-43.
Tony
Name:	MM S-43 loader picture.jpg
ID:	339237   Click image for larger version
Name:	S-43 attachments.jpg
The Following User Says Thank You to Tony Thompson For This Post:
Old 07-17-2019, 10:34:11 AM
Molinegb Molinegb is offline
MM industrials used the L series on industrials. L400,500,etc Usually can tell by the bell crank setup and leveling arms on top. Have to pickup a L500 loader for my Jetstar 3 industrial diesel someday. Lull and Reese used on earlier models R's. Not sure who made L series. Ottawa and Paulson made for MM as well as Schwartz.
The Following 2 Users Say Thank You to Molinegb For This Post:
Old 07-17-2019, 11:24:35 PM
ulgydog56's Avatar
very nice Minnie mo......
The Following User Says Thank You to ulgydog56 For This Post:
Old 07-18-2019, 04:10:52 PM
Hello all,
Here is a brochure cover from 1964 that shows the L400 & L500 Heavy duty loader. These appear on industrials and the "big mo" series tractors as well as some Jets.
It is very similar to mine, but not the same. Bucket leveling arms are on top and had grill guard.
The type of loader I have seems older than the 60s MM 400-500.
I believe the 335 has had this loader for life and if that is true then it would be 1958 area?
Have not discovered who made loaders for MM.
Could this be a late Lull or Reese?
Parsons made them, but may be newer.
Ottawa?
Schwartz?
Paulson?
Will keep snooping and would appreciate any leads from our brilliant and helpful network here. Thanks,
Tony
Old 09-09-2019, 11:44:31 AM
Hello all,
The MM has been a handy loader that is capable of lifting enough weight to raise rear wheels up causing complete loss of traction. I installed a pair of beefy vintage weights to combat this issue and it made a big difference.
I am at a complete loss for trying to ID this loader and still looking for help from the public. Hopefully someone in our network will recognize it.
Good luck on your projects everyone!
Tony
Name:	MM 335 ind..jpg
ID:	343577   Click image for larger version
Name:	MM 335 indusrial.jpg
The Following 4 Users Say Thank You to Tony Thompson For This Post:
Old 09-10-2019, 10:34:08 AM
The Gresen valves kinda date loader to mid 60's. Charlyns were used on in 50's and early 60's
The Following 3 Users Say Thank You to Molinegb For This Post:
Old 09-12-2019, 09:18:12 PM
Found an old MM memo dated 1962 to update M5 Charlyn to Gresen. Charlyn leaked when warm. Probably doesn't help. Looks like ones on Masseys. Many loaders were made here and went defunct Still one nice loader.
Old 11-09-2019, 02:48:54 PM
No luck identifying this loader brand yet.
I have been using the tractor around the acreage all year long. It is very handy, fits in narrow areas, under low doorways and tree-limbs.
Tony
Name:	Fall yard work with 335 MM 002.jpg
ID:	348673   Click image for larger version
Name:	Fall yard work with 335 MM 003.jpg
The Following 2 Users Say Thank You to Tony Thompson For This Post:
1958 Minneapolis Moline 445 Molinegb Antique Farm Tractors 13 03-25-2017 07:07:19 PM
Minneapolis-Moline UTOX and Minneapolis-Moline UDLX Mecum Auctions Live Auctions of Engines, Tractors and Old Iron 0 04-19-2016 04:12:46 PM
Minneapolis Moline R industrial with Lull loader Tom S Antique Farm Tractors 3 01-13-2015 08:07:29 AM
Continental ID in a MF industrial wheel loader jandg Antique Farm Tractors 4 02-23-2010 10:44:05 AM
1950 Case D Industrial w/Lull front loader dieseldave56 Antique Farm Tractors 0 06-21-2008 02:35:10 AM
