IH Cub Lo boy. The saga continues
this thread has 34 replies and has been viewed 1189 times
Old 09-26-2019, 09:42:24 AM
VicF VicF is offline
Default Re: IH Cub Lo boy. The saga continues
Originally Posted by Tracy T View Post
Not sure I follow, slight ignition??? engine trys to start but wont? ignition spark weak? as for the quality of parts that can be a problem. your local NAPA may have them on the shelf, they did for my 1973 IHC engine and they used the same parts on many different engines. Just had a thought though, can you post a close up picture of the distributor?
I can hear a cylinder fire but nothing else. I'm going to give my local NAPA a call to see if they do. I'll try to get a picture.
Old 09-26-2019, 09:44:59 AM
Tracy T Tracy T is offline
I ran into a issue on mine that sounds exactly like the problem you are having with yours, but I dont want to confuse the thread if your engine has a different distributor.
Old 09-26-2019, 09:48:10 AM
It's the standard cub distributor. horizontally mounted.
Old 09-26-2019, 09:54:58 AM
If you cant post a picture I can post one of mine for you to compare yours to, if they are the same there is a set of gears that are supposed to be greased One shot of grease every so many hundred hours. There is only a plug there no grease fitting and most people are unaware of this and they never get greased and wear out! IH didnt put fittings there for a reason too, you can over grease it and cause problems thats why they opted for plugs insted of fittings. these gears are available and i got mine either from steiner or All States AG I cant recall that was over two years ago.
Old 09-26-2019, 10:01:11 AM
here is a picture of my engine off of the net, its not the same engine this is a c135 OHV but look at the distributor. Is that what you have?
https://images.app.goo.gl/1iSHBFbu4wVTPaVd6
Old 09-26-2019, 10:21:54 AM
yes thats the same distributor.
Old 09-26-2019, 10:31:11 AM
seperate it at the timing cover and inspect your gears best i recall the worst that can happen is you can get it out 180 degrees so pay attetion to where the rotor is pointing before you take it apart. can you see the slotted plug in the picture? thats where I installed a grease fitting. there is a thread i started here on the stak I dont recall which subfourm either aircompressors or farm tractors about the issue i ran into. gears were cheap.
The Following User Says Thank You to Tracy T For This Post:
  #28
Old 09-26-2019, 10:33:20 AM
I was wondering what the plug was for. I hate taking off the distributor but I guess it has to be done.
Old 09-26-2019, 10:40:44 AM
only two bolts, pop the cap off let it hang by the plug wires mark rotor postion on dist body. I have my steiner book out part #IH5815 was bad on mine $28.95 + shipping/tax.
Old 09-26-2019, 10:45:41 AM
while you have the dist out you can set the points or double check your work on the work bench. mine ran like crap and finally quit, all new parts same as you before i found the actual problem. was a real hair puller until i found the cause.
Old 09-26-2019, 10:57:37 AM
I found my other thread on this subject, dont know how to link it but there is not much there that i have not already covered here. Its title is distributor drive gear i believe. good luck and keep us posted on your findings!
Old 09-26-2019, 04:18:23 PM
EdDarowski EdDarowski is offline
I don't know how far you are from NY, but, if you can get it to a Cubfest we're having, Columbus day weekend, there will be a bunch of cub owners there, that can help you. Check farmallcub.com forum, for Northeast cubfest, or PM me if you need info.
Ed
Old 10-14-2019, 03:32:18 PM
So I sent the carb in for a rebuild. Steiner carb parts were wrong. I now have ignition and it really wants to start. Strange popping noise coming from the oil cap.
Old 10-14-2019, 08:40:10 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Have you run a compression test? If your description of popping at the oil filler cap is accurate, you may have issues with rings or a burned thru piston. I also have had a issue with after market points, The points for a newer distributor are different from the old tractors. Trouble is the application listing on some listings on the package are wrong, they wont work as the rub block on the set is in a different position. therefore the points don't open at the same place it needs to and the internal timing in the dist. don't match the rotor cap.
Old 10-31-2019, 09:48:14 AM
UPDATE: Had my local mechanic take a look. It was a blown head gasket! Here I was doubting my competence when in reality everything I did was fine.
Farm Master (Cub) R40 Saga continues.... dondlhmn Hit & Miss Gas Engine Discussion 1 01-04-2012 05:03:17 PM
Work Continues on 6 hp IHC international harvester co. continues RobGill2008 Hit & Miss Gas Engine Discussion 2 08-14-2010 11:26:09 PM
The $600 IHC 6 H.P. "M" saga continues? Fred Van Hook Hit & Miss Gas Engine Discussion 4 07-15-2009 06:51:59 PM
The saga continues... (Fuller Johnson) KyleBlankenship Hit & Miss Gas Engine Discussion 3 02-26-2008 12:22:22 AM
Briggs FH Carburetor Saga Hal Davis Antique Engine Archives 2 01-06-2003 09:01:04 PM
