1947 Moline RTU compression test
this thread has 5 replies and has been viewed 375 times
Old 09-14-2019, 09:36:52 PM
rellisonii rellisonii is offline
Question 1947 Moline RTU compression test
How much cylinder pressure should i have on a healthy engine? all four cylinders on my tractor are low 90s. the reading does not increase with oil added to the cylinders. I pull stock class and am running out of power and stalls at end of pull. I am trying to decide if I should try making stock engine run better, or if needs overhauled, find a 206 to put in and go from there. Thanks for any ideas.
Old 09-14-2019, 11:41:30 PM
ulgydog56's Avatar
Default Re: 1947 Moline RTU compression test
don't know what the spec on compression is but 90 lbs sounds good to me, old tractors had low compression engines for long life at rated rpm, auto motors would blow up in no time at max rpms.......ps if you mod or change-no more stock class, witch is cool too....or put a super kit in it....
Old 09-15-2019, 09:08:11 AM
Molinegb Molinegb is offline
Long as compression close to equal on all 4. R in new condition might hit 120.
The Following User Says Thank You to Molinegb For This Post:
Old 09-15-2019, 01:35:22 PM
What is a Super Kit?
I don't want to put a bunch of money into the stock motor since it seems to be easy swap to a za 206, moving the flywheel and pressure plate from the r to the z motor. doubt a perfect running r engine will ever make the power a z can.....
Old 09-15-2019, 11:53:54 PM
ulgydog56's Avatar
most tractor rebuilds offer a super kit, 10 thousands over on pistons or higher compression, not much more money than a standard rebuild kit, just check the internet to see who offers it for the Minnie mo,s…...
Old 09-16-2019, 08:58:36 AM
Good luck finding someone to bore blocks as blind hole. Oversize pistons will be tough to find as they are not flat on on top. You won't gain anything.
1947 JD Model B cylinder compression specs 177tony Antique Farm Tractors 3 08-03-2015 08:04:32 PM
Minneapolis Moline GB Diesel, Compression Check. Stevexoc47 Antique Farm Tractors 5 05-10-2014 09:10:05 AM
Compression test Swamp239 Wisconsin Engines 3 11-16-2013 04:10:36 PM
Small B&S Compression test Bigjoedo Small Air Cooled Gasoline Engines 4 08-25-2011 03:27:07 AM
Maytag 72D compression test? KeithW Maytag Engines and Collectibles 10 07-12-2005 02:16:31 PM
