Fairbanks Morse z mixer 6hp
this thread has 4 replies and has been viewed 294 times
Old 09-17-2019, 07:05:31 PM
tdadams tdadams is offline
Default Fairbanks Morse z mixer 6hp
Fairbanks Morse z 6Hp fuel mixer pick up tube.
How does the copper line attach to the hole in the needle valve. Solder? It appears to be a replacement valve but never got hooked up due to the fact there is no fuel tank. Ordered tank today.
Old 09-17-2019, 09:48:12 PM
Turbo's Avatar
Turbo Turbo is offline
Default Re: Fairbanks Morse z mixer 6hp
Yes, it is soldered.
Old 09-18-2019, 05:22:20 AM
Thanks.That makes it easy!
Old 09-18-2019, 01:37:11 PM
There should be a 1/4 OD copper line that goes into the fuel tank. There should be a check valve on the bottom. They will hang by the fuel line about 1/4" above the bottom of the tank, to keep the line from sucking up debris and water from the bottom of the tank. Depending on model, there may be a second supply that the fuel nozzle is attached to. This is an anti-knock water supply that mixes water with the kerosene when the engine is heavily loaded. It will have a seperate valve, at a right angle to the main fuel valve. It is not nescessary if you run on gasoline only.
Old 09-18-2019, 02:26:49 PM
Pat Barrett Pat Barrett is online now
And before you solder it, be sure to put the tank cap ( 1/4" hole in center on the copper tube before soldering.
The Following User Says Thank You to Pat Barrett For This Post:
Fairbanks Morse T mixer. R Shannon Hit & Miss Gas Engine Discussion 10 02-08-2013 09:55:01 PM
Fairbanks Morse 1.5 hp Mixer question baklys Hit & Miss Gas Engine Discussion 5 08-12-2012 04:49:06 PM
Fairbanks Morse Z 6hp Mixer Tilinghast Hit & Miss Gas Engine Discussion 7 03-17-2010 05:02:52 PM
Fairbanks Morse Headless Mixer jc100 Hit & Miss Gas Engine Discussion 3 03-25-2009 07:00:34 PM
fairbanks morse mag and mixer help Donnie Devore Sr. Hit & Miss Gas Engine Discussion 8 01-28-2006 10:43:35 AM
