Oliver 770 throttle issue
this thread has 5 replies and has been viewed 321 times
Old 10-11-2019, 02:40:27 PM
Alan Wakefield Alan Wakefield is offline
Default Oliver 770 throttle issue
Hello everyone! I've been trying to figure out the problem with my neighbors Oliver 770. There isn't any throttle response at the lever on the steering column. It's either low idle or very fast to the point of over revving nothing in between. He said he was raking hay and it started over revving right out of the blue. What should I be looking for, something with the governor or a broken spring somewhere in the linkage? Thanks for any help anyone can send my way!
Old 10-11-2019, 11:53:01 PM
ulgydog56's Avatar
Default Re: Oliver 770 throttle issue
start at the throttle and work back to the carb and gov...
The Following User Says Thank You to ulgydog56 For This Post:
Old 10-12-2019, 01:29:16 PM
ibdennyak ibdennyak is offline
If diesel, it could be the injection pump needs repair.
The Following User Says Thank You to ibdennyak For This Post:
Old 10-12-2019, 05:42:01 PM
O. K. early 770 tractors used a Bosch PSB injection pump. I n the summer of 1960 the Bosch was discontinued and they went to a Roosa Master DB pump, which do you have and what is the serial number of the tractor and the model number of the injection pump?
Old 10-15-2019, 10:08:59 AM
This 770 is gas.
Old 10-15-2019, 11:29:30 AM
O. K. Have you looked at the external linkage. Have you removed the governor housing and inspected the weight assembly, the thrust bearing and the thrust washer behind the weight assembly? Send me an e-mail to my personal e-mail and include your phone number. I worked for an Oliver dealer when those tractors were new. Oh, how many active coils are there on the governor spring?
The Following User Says Thank You to John Schwiebert For This Post:
Wisconsin VG4D - Surging throttle issue Aston01 Wisconsin Engines 4 09-19-2019 07:20:10 PM
Oliver 77 & Oliver Super 77 Parts Book / Manual TractorDom Service Manual Scans 4 04-18-2019 10:40:22 PM
oliver 77 peter1020 Antique Farm Tractors 2 01-22-2014 02:08:06 PM
Ford 2N Oliver with Oliver E 729 Loader bigGURN Antique Farm Tractors 1 09-07-2012 10:43:37 PM
Oliver 2-way trowel Horse Drawn Equipment 2 02-27-2011 10:52:29 PM
