Question re: gib keys w/split hub flywheels
this thread has 4 replies and has been viewed 516 times
Old 10-15-2019, 05:28:20 PM
Chris Kirk's Avatar
Chris Kirk Chris Kirk is offline
Default Question re: gib keys w/split hub flywheels
Hello!
I'm going to be reassembling my FM-Z in a few weeks. The flywheels have split hubs with gib keys.
Do I insert the gib keys, then tighten the hub bolts, or tighten the hub bolts then insert the gib keys?
Thanks...
Chris
Old 10-15-2019, 06:06:32 PM
Mike Lucius's Avatar
Mike Lucius Mike Lucius is offline
Default Re: Question re: gib keys w/split hub flywheels
Tighten the bolt first then drive in the key. Doing the opposite is a sure way to crack a flywheel.
Old 10-15-2019, 07:19:20 PM
Dustin D Ehli Dustin D Ehli is offline
You sure they are gib keys, on all the splits I have worked on had a straight key, but either way yes tighten the bolt pretty good before pounding in the key
Having a blast preserving the past.
My Youtube Channel
The Following User Says Thank You to Dustin D Ehli For This Post:
Old 10-15-2019, 07:56:21 PM
Tom Gosciminski Tom Gosciminski is offline
Split hub flywheels always use straight key (never a gib key)
The Following User Says Thank You to Tom Gosciminski For This Post:
Old 10-17-2019, 11:51:47 AM
Chris Kirk's Avatar
Yes, sorry, they ARE straight keys, NOT gib keys.
Thanks for the responses.
Chris
Split rim Question? Adam Hartz Antique Autos and Trucks 18 03-16-2011 10:26:33 PM
Installing Flywheels and keys Tim Claremont Hit & Miss Gas Engine Discussion 3 11-19-2008 08:11:06 AM
Question on Split Winding Transformer David W. Onan Generators 2 01-19-2007 05:13:54 PM
Correct procedure for installing split hub flywheels??? Gasengin Hit & Miss Gas Engine Discussion 5 08-29-2006 02:33:43 PM
Fitting tapered keys to flywheels & crank shaft. Paul F Brien Antique Engine Archives 0 09-21-1999 10:13:52 PM
