What's your winter project for the 2020 season?
this thread has 29 replies and has been viewed 2636 times
Old 10-19-2019, 11:30:01 AM
SDP's Avatar
SDP SDP is offline
Default What's your winter project for the 2020 season?
I'm working on this 4 horse Famous. Needs a new fuel tank and would like to get trucks on a heavy cart made up.
Please feel free to share your projects. 2020 is a big year for many shows around North American.
Name:	4 HP FAMOUS.jpg
The Following 5 Users Say Thank You to SDP For This Post:
Old 10-19-2019, 01:49:31 PM
ThreeHitsandaMiss ThreeHitsandaMiss is offline
Default Re: What's your winter project for the 2020 season?
I have several sets of steel wheels for a cart id be willing to sell and live 10 minutes from you.Like your Famous they are one of my favorite engines,well designed and great runners.
The Following User Says Thank You to ThreeHitsandaMiss For This Post:
Old 10-19-2019, 02:43:07 PM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
Just got this 13/4 Frost King Jr , https://youtu.be/jF0TdQXBJqQ then got sick the next day fighting 102-3 fever just unloaded out of truck finally today. And waiting for rod and piston, head with new valves for this. https://youtu.be/wMvk3GNjHFU 5hp Challenge flattop, a early one with the hourglass head with exhaust out of top.of head and Diamond L carb,after I get it running off a external tank the main bearings will need repoured ,cant run out of cast tank until that is done... Also need a break on this health issue that keeps cropping back up..
United Gasoline Engine Registry www.augermo.com
The Following 4 Users Say Thank You to Rich Mueller Sr For This Post:
Old 10-19-2019, 04:54:44 PM
Kevin Weis Kevin Weis is offline
For me a 1 3/4 Sattley throttle governed solid flywheels. Needs lots of parts so will be a winter long project.
The Following 2 Users Say Thank You to Kevin Weis For This Post:
Old 10-19-2019, 09:11:03 PM
Kyle McGee's Avatar
Kyle McGee Kyle McGee is offline
I would be interested in a set of wheels, I will message you.
Thanks kyle m
Old 10-19-2019, 09:24:36 PM
Lou Quirch Lou Quirch is offline
New garage with coachhouse apartment on top.
Lou
The Following 2 Users Say Thank You to Lou Quirch For This Post:
Old 10-19-2019, 09:59:45 PM
CBarth66 CBarth66 is offline
Restoring a 2 hp. Domestic type A, putting a steel wheel cart under a 6 hp. Ohio Pushrod and painting a 1 1/2 hp. Stover K.
The Following 2 Users Say Thank You to CBarth66 For This Post:
Old 10-19-2019, 10:36:18 PM
Dustin D Ehli Dustin D Ehli is offline
18-36 Hart Parr
Having a blast preserving the past.
My Youtube Channel
The Following 2 Users Say Thank You to Dustin D Ehli For This Post:
Old 10-20-2019, 12:02:22 PM
ohiomotorco ohiomotorco is offline
2 HP Leader-Domestic, installed in a lake side pumphouse in 1911, removed in 1999 by me via barge! Mechanical restoration only, it is great original condition, lots of striping and paint visible under the grease.
The Following 2 Users Say Thank You to ohiomotorco For This Post:
Old 10-20-2019, 04:52:44 PM
bryanb1138 bryanb1138 is offline
Any pictures of the Ohio push rod? in process of building a cart and cleaning one up myself.
The Following User Says Thank You to bryanb1138 For This Post:
Old 10-20-2019, 06:08:59 PM
Here you go. A couple pics of the Ohio, one of the Domestic and one of the Stover. May paint the Ohio too. There's no paint left on it or I might consider leaving it as is. I need to get a repo brass tag for it. The axles and wheels I am using are off an old Eagle silo filler. Got the pictures turned around finally.
ID:	347182   Click image for larger version
ID:	347183   Click image for larger version
ID:	347184   Click image for larger version
The Following 3 Users Say Thank You to CBarth66 For This Post:
Old 10-20-2019, 08:06:44 PM
forney00c forney00c is offline
My winter project is a 1921 1-1/2 HP International Harvester M overstrike ignitor engine with a dealer conversion to spark plug and Wico EK.
The Following 2 Users Say Thank You to forney00c For This Post:
Old 10-20-2019, 08:44:50 PM
Dave Nielsen Dave Nielsen is offline
I guess for me its to finish my Fathers and my 1909 4hp screen cooled Famous as well as do some work on my Lauson Lawton. Dave
The Following 5 Users Say Thank You to Dave Nielsen For This Post:
Old 10-21-2019, 07:41:14 PM
Roland Finkenbinder Roland Finkenbinder is offline
I picked up a 1-1/2HP or so Waterloo contract engine at Coolspring in June and have started painting the individual parts while the weather is still warm. It is missing the name plate(seems like a lot of the contract engines are). My friend claims there must have been a bounty on them. I have most of the parts rounded up and a new igniter made for winter assembly. It is #94645 and I remember seeing a 1914 casting date on the block during cleanup. Anyone have a name plate lying on a shelf that would work ?
The Following 2 Users Say Thank You to Roland Finkenbinder For This Post:
Old 10-22-2019, 08:40:39 AM
VicF VicF is offline
Oliver 77 Radiator replacement. Also found Allis-Chalmers C for relatively cheap that I'm going to try and restore.
The Following User Says Thank You to VicF For This Post:
Old 10-22-2019, 04:29:36 PM
Woody Sins's Avatar
Woody Sins Woody Sins is offline
Standard 5 HP. I had a base made for it, and have a tank on order. Some minor repairs, skids, and so on will complete it.
ID:	347279   Click image for larger version
The Following 4 Users Say Thank You to Woody Sins For This Post:
Old 10-22-2019, 06:51:02 PM
Donnie Hargreaves Donnie Hargreaves is offline
I will be rebuilding the cart for my 8 hp Sparta economy engine.Will post pictures throughout the project.
The Following 3 Users Say Thank You to Donnie Hargreaves For This Post:
Old 11-03-2019, 09:24:14 PM
Galan Hackman Galan Hackman is offline
Here is one I just started. Engine is in pretty bad shape.
The Following 3 Users Say Thank You to Galan Hackman For This Post:
Old 11-03-2019, 09:42:29 PM
fairbanksmogual fairbanksmogual is offline
This winter is build a lineshaft lathe and drill press display. Three Fairbanks Morse engines, 1 1/2 hp dishpan, 3hp and 6hp z.
The Following User Says Thank You to fairbanksmogual For This Post:
Old 11-04-2019, 03:36:44 PM
Emil K Emil K is offline
I'm going to try and finish my 6-HP Warner. Have all the parts now and it will be painted, Someone screwed it all up with red spray paint and there is no original paint left. Will need to build a cart for it also. Thanks....
The Following 2 Users Say Thank You to Emil K For This Post:
CH&E Winter Project lil herc Hit & Miss Gas Engine Discussion 10 04-02-2018 11:24:45 AM
Another winter project done Brickman Hit & Miss Gas Engine Discussion 5 12-22-2008 10:11:01 PM
Another winter project ready for show season Andy Delikat Antique Engine Archives 5 05-15-2004 06:59:06 AM
Winter project (before) Eric McKenna Antique Engine Archives 6 12-25-2002 10:19:58 AM
