Scale Model Engineering Steam, gas and hot air model engines, tractors, trains and accessories. Machining and milling castings.
PM Research Machine Shop
this thread has 4 replies and has been viewed 3247 times
Old 11-30-2008, 01:11:55 AM
James L Johnson's Avatar
James L Johnson James L Johnson is offline
Default PM Research Machine Shop
Enclosing some pictures of a PM Research machine shop Lathe, Pedestal grinder,Drill press,Shaper, Horizontal mill and a foot powered wood lathe.
ID:	44165   Click image for larger version
ID:	44166   Click image for larger version
ID:	44168   Click image for larger version
Old 11-30-2008, 10:45:52 AM
gbritnell gbritnell is offline
Default Re: PM Research Machine Shop
Nice work James. When did you build these? I have just finished the engine lathe and will probably tackle the shaper next. It looks like you used 12L14 for some of your handles. You have to keep that stuff oiled up because it certainly likes to rust.
gbritnell
Old 11-30-2008, 11:50:36 AM
Wayne A Thackery's Avatar
Wayne A Thackery Wayne A Thackery is offline
Jim, was good to see you yesterday and the Holt was a real treat to see in person! The oil pump is a great inprovement over the old drip system. I was wondering if you could post a picture of the whole machine shop, showing the lineshaft and all the equipment. Until we meet again.......keep a cool tool!
Old 11-30-2008, 10:56:00 PM
gbritnell
The machine shop was built by the same person that built the Hotl.
I'am building a roof structure over the machin shop with a couple lights so everything shows up good. I will also put a engine house to the back and put in a steam engine and stationary engine, these will be for looks only as I will use the dc electric motor that drives the line shaft now.
Jim
Old 11-30-2008, 11:35:40 PM
Wayne:
I have 2 pictures showing the complete shop will post them.
Had a good time at Brooks always interesting.
Jim
ID:	44246   Click image for larger version
The Following 3 Users Say Thank You to James L Johnson For This Post:
Machine shop recommendation? gearhead1 Hit & Miss Gas Engine Discussion 5 08-23-2007 03:34:11 PM
Is there room for another machine shop? Rob Charles Antique Engine Archives 8 09-05-2002 07:45:14 PM
Machine Shop Course enginenut Antique Engine Archives 1 02-12-2002 11:05:54 AM
machine shop bill Antique Engine Archives 4 01-06-2002 04:24:59 AM
Machine Shop Runaround Bob Naske Antique Engine Archives 28 02-01-2001 10:05:41 PM
