Won't start - 17.5HP Briggs and Stratton
this thread has 2 replies and has been viewed 5744 times
Old 08-08-2010, 02:42:46 PM
Unmechanical Unmechanical is offline
Default Won't start - 17.5HP Briggs and Stratton
Another dumb question: I have a 17.5 HP Briggs and Stratton on a 6 year old Troy Built rider mower. Every other week, it won't start. I replace the battery (thinking it's a bad one). The mower will start that week, but after a week of storage, the engine turns just a little, but won't start. I've taken the battery back twice and it does the same thing. I store it with the key off and the seat up so the contacts are not hitting. I've changed the spark plug, fuel filter and oil recently. Any ideas why and what I can do? Thanks
Old 08-08-2010, 05:05:22 PM
K D Redd K D Redd is offline
Default Re: Won't start - 17.5HP Briggs and Stratton
Try, when you stop the engine, unplugging the anti-dieseling solenoid on the bottom of the carb. If the battery is not run down after a week, SOMEONE has messed up the wiring on your mower or installed the WRONG ignition switch. Have you tried charging the battery instead of returning the battery?
Kent
Old 08-09-2010, 12:09:59 AM
Motormowers's Avatar
If its an unregulated charging system there is a diode on the pigtail harness coming off the engine. Unplug the connector at the engine and let it sit. If its OK the diode is bad and voltage is back feeding to your stator.
Briggs and Stratton ID Outlaw Small Air Cooled Gasoline Engines 8 08-02-2009 09:47:58 PM
Briggs & Stratton I. D. Help John Schwiebert Small Air Cooled Gasoline Engines 1 01-19-2009 01:02:56 PM
Where to start - Briggs and Stratton 6S Adam F Small Air Cooled Gasoline Engines 2 10-28-2007 09:59:52 PM
Briggs Stratton ZZ Patrick McNallen Small Air Cooled Gasoline Engines 12 10-10-2006 02:29:53 PM
Briggs & Stratton 5s - Where to start restoring? gearedsteam Small Air Cooled Gasoline Engines 92 12-16-2005 02:36:05 PM
