Briggs ~ MAY DAY MAY DAY - Briggs Z coil rewind badly needed!
this thread has 6 replies and has been viewed 1063 times
Old 03-19-2017, 09:05:16 PM
Jack H's Avatar
Jack H Jack H is offline
Thumbs up Briggs ~ MAY DAY MAY DAY - Briggs Z coil rewind badly needed!
Help folks! I have two dead Briggs Z coils in serious need of rewinding.
Can anyone please refer me to someone who rewinds coils and will do a quality job?
Thanks in advance,
Jack
Old iron for an old Gearhead:http://www.antiquebriggsandstratton.com/
Old 03-19-2017, 10:39:40 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
Default Re: Briggs ~ MAY DAY MAY DAY - Briggs Z coil rewind badly needed!
Try Mtch Malcom
The Following User Says Thank You to Steve Kreiner For This Post:
Old 03-20-2017, 06:02:15 PM
Bolens 1000 Bolens 1000 is offline
warehouse shows two new ones left $295 each at a distributor I seal with
if you can find someone to rebuild yours
The Following User Says Thank You to Bolens 1000 For This Post:
Old 03-20-2017, 08:21:15 PM
Junkologist's Avatar
Look here.
http://www.oldcroak.com/briggs-strat...ound-exchange/
I know others that have bought these and were happy with them.
Mike
SmokStak member #146
Old 03-21-2017, 01:57:56 AM
Vanman Vanman is offline
And I'll put in that the folks over there have been extremely helpful and quite a pleasure to chat with.
Keith
Old 03-21-2017, 08:31:15 AM
batrider batrider is offline
I rewound my Model A coil very carefully with a hand winder and after going through that I'd say Old Croak's price is a bargain. There is a lot of work that goes into it. If you are properly set up with a winding machine it helps but it is still very labor intensive.
Russ
Old 03-21-2017, 10:50:23 AM
Everett Hayden's Avatar
Everett Hayden Everett Hayden is offline
Thanks in advance,
Jack
Jack, I have a NOS one. I just sent you a PM.
Everett
Briggs & Stratton armature coil rewind Restofire Magnetos, Ignition Coils and Spark Plugs 4 10-06-2013 08:39:38 PM
Cost of coil rewind for Briggs WMB? thetractorfreak Small Air Cooled Gasoline Engines 5 12-04-2011 11:39:17 AM
Briggs FH bad coil needed makoman1860 Magnetos, Ignition Coils and Spark Plugs 7 12-28-2009 08:15:50 PM
Badly stuck Briggs 5s Breaker Point Plunger James Wallace Small Air Cooled Gasoline Engines 3 11-07-2008 06:37:58 PM
Coil needed for a Briggs 23D. HELP!!! glock35ipsc Small Air Cooled Gasoline Engines 6 01-09-2005 02:53:56 AM
