Root and Vandervoort 12 HP Portable Engine Restoration
this thread has 143 replies and has been viewed 34123 times
Old 12-01-2013, 10:23:29 AM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
Default Re: Root and Vandervoort 12 HP Portable Engine Restoration
Cleaned up base:
-Jeff
wahlengines.com
Old 12-01-2013, 10:29:08 AM
Jeff Wahl's Avatar
Discs:
Found rear of cylinder has a good size chunk broken out. Might have thrown a rod at one point. Also found the piston upside down in cylinder, potentially from installation after the repair. Not good for getting oil to the piston wrist pin!
-Jeff
wahlengines.com
Old 12-01-2013, 10:32:34 AM
Jeff Wahl's Avatar
Also found two sets of numbers stamped on the rear rim of the cylinder: 8850 and 12....serial number and horsepower???
-Jeff
wahlengines.com
Old 12-19-2013, 10:44:01 PM
Jeff Wahl's Avatar
Originally, I had some doubts that 8850 could be the serial number for my R&V as I wasn't sure if they were making hopper cooled engines that early. Then found these photos I took at the 2003 R&V reunion of an 8 HP R&V engine with detachable hopper. I believe there was a GEM article on this R&V that was found in the woods and restored to present condition. It's serial number is E 8763. So this engine would seem to confirm that they were making hopper cooled engines that early and my R&V would have been made 87 engines after this one!
-Jeff
wahlengines.com
The Following 5 Users Say Thank You to Jeff Wahl For This Post:
  #85
Old 12-20-2013, 01:54:30 PM
Jeff Wahl's Avatar
So now I need to find or make a new brass tag for the R&V. It had a four screw 4" square brass tag mounted to the cylinder plate. I believe it was similar to the tag in the picture below, where the last part about location was different depending on the Deere Implement Co. the engine was shipped to. As this engine came from Georgia, I'm assuming it would have been the Deere Implement Company in Atlanta, Georgia.
Does anyone have an extra tag like this laying around that I could buy?
Does anyone have a tag like this that I could borrow to have copied?
Who out there can reproduce a tag like this?
Appreciate any help!!!
-Jeff
wahlengines.com
Old 12-20-2013, 02:25:21 PM
Dwight Vivas Dwight Vivas is offline
Hey Jeff
Try these folks -http://www.vintagebrassplates.co.uk/
Never used them, but their work looks nice !
The Following User Says Thank You to Dwight Vivas For This Post:
  #87
Old 12-20-2013, 03:05:03 PM
RVandervoort1 RVandervoort1 is offline
Wow Jeff she is coming along Beautifully!! I wish I could find one like that in the wild. Will you have it a butterfield this year? Dad and I are thinking we are going to ride our bikes down on fri or sat this year. Looking forward to seeing your other engines and meeting you. I believe you already know my dad as he said I should meet you. Happy holidays. Jay
The Following User Says Thank You to RVandervoort1 For This Post:
  #88
Old 12-20-2013, 03:10:50 PM
LCJudge LCJudge is offline
Jeff, this is what the tag for the 6 HP Electric Lighting R&V Sideshaft looked like. I assume all of them had JD Plow Company on them.
Name:	R&V Engine 1.jpg
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
  #89
Old 12-20-2013, 03:40:09 PM
Fifty7ChevyNut Fifty7ChevyNut is offline
I have used a needle scaler to dimple cast iron, and then let it rust and wire wheel. Do this a few times, and the repair should almost be undetectable.
Thoughts?
Don
The Following User Says Thank You to Fifty7ChevyNut For This Post:
  #90
Old 12-20-2013, 04:24:25 PM
Exclamation Re: Root and Vandervoort 12 HP Portable Engine Restoration
The breakout in the cylinder probably was caused by a broken or dropped (read cap came off) con rod. You might be able to find a section of cast iron plumbing waste pipe, close to the diameter needed. Cut a section to match the break and weld or braze in, and machine. A good gas welder should be able to fill in the break, but it will take a bit of heating to get it right.
Nice work, keep us posted!
  #91
Old 12-20-2013, 10:17:43 PM
Mike Monnier's Avatar
Hoarder
Tommy, I saw a 6hp tank cooled at Portland several years ago with a Deere & Webber tag on it. However, I believe John Deere Plow Co. shows up on most R&V engines. That would be the correct designation for an engine sold through the Atlanta branch house.
The Following 2 Users Say Thank You to Mike Monnier For This Post:
  #92
Old 12-20-2013, 11:56:45 PM
Jeff Wahl's Avatar
I may have been wrong on the tag. The screw holes are 3 5/8" apart across and 3 1/2" apart front to back. So instead of the square R&V tag, it was probably like the one Tommy posted.
If you go to the following link, you can see all the variations of R&V tags. There was John Deere Plow Co., Deere & Weber, Deere Implement Co., etc. The middle tag 4 rows down appears to be a repro tag that would work on my engine. Does anyone know where I can get one?
http://www.oldengine.org/members/plo...gines/tags.htm
Jay, this R&V engine is currently in Virginia. Not sure if it will make it to Butterfield, MN. However, we have 2 other nice R&V engines there, so you should still come!
Don, we used a needle scaler on the wheels/cart some already. They look good enough for now, but you are right, we could let them rust outside awhile to blend them better.
Andrew, we could get cylinder fixed, but don't think it is necessary. We can come back to it later if needed.
-Jeff
wahlengines.com
The Following User Says Thank You to Jeff Wahl For This Post:
  #93
Old 12-21-2013, 11:08:00 AM
Jeff Wahl's Avatar
I now own a very very rare single flywheel Root & Vandervoort engine!
-Jeff
wahlengines.com
Old 12-21-2013, 07:52:14 PM
Jeff Wahl's Avatar
Even comes with an original factory spare!
-Jeff
wahlengines.com
Old 12-21-2013, 09:36:49 PM
Great Jeff. As you know, I need a flywheel.......
This "spare one" will work just fine!...
Tommy Turner
The Following 3 Users Say Thank You to LCJudge For This Post:
  #96
Old 12-23-2013, 10:10:46 AM
Jeff Wahl's Avatar
Some more photos of the outstanding work and progress Justin has made on the R&V. Some details:
-made new sideshaft as the original was badly pitted in spots
-cleaned up side shaft and governer gears
-resurfaced side shaft cams, replaced rocker arm rollers
-all new nuts/bolts as the as originals were pitted
-resurfaced governer tower and replaced adjustments
-replaced lubricating chain for the bearings
-machined surface of pulley for water pump
-resurfaced cylinder faces
-connecting rod cleaned and waiting for piston to get fitted with new rings
-etc, etc!
-Jeff
wahlengines.com
The Following 7 Users Say Thank You to Jeff Wahl For This Post:
  #97
Old 12-23-2013, 10:14:22 AM
Jeff Wahl's Avatar
-Jeff
wahlengines.com
  #98
Old 12-23-2013, 10:24:26 AM
Jeff Wahl's Avatar
-Jeff
wahlengines.com
Old 12-23-2013, 07:57:54 PM
Card Sponsor
Hi Tom and Jeff, Looking good. I'm glad you let Justin talk you into replacing the pitted parts with new. Hope to see it running sometime. Rob
The Following User Says Thank You to Rob Charles For This Post:
  #100
Old 12-23-2013, 11:01:49 PM
HBurk HBurk is offline
I see ole Justin is takiner easy.
Tags
engine
A Root & Vandervoort 1HP - ½ scale engine Paul Spence Hit & Miss Gas Engine Discussion 3 06-30-2011 12:15:02 PM
Root & VanDervoort Engine Register OzEngines Hit & Miss Gas Engine Discussion 0 11-22-2007 02:16:41 AM
Root & VanDervoort Engine Register OzEngines Hit & Miss Gas Engine Discussion 0 08-17-2007 07:49:50 AM
Root-Vandervoort hoist engine Schramm Hit & Miss Gas Engine Discussion 1 01-30-2006 04:36:31 AM
Root & Vandervoort engine Bob Johnson Antique Engine Archives 2 07-31-2002 11:18:33 PM
