Go Back   SmokStak > SmokStak® Vintage Electrical Equipment > Kohler Generators
Kohler Generators
I want to run my Natural Gas Generator off of Propane. What do I need to know?
this thread has 6 replies and has been viewed 3728 times
Old 04-07-2012, 10:31:58 PM
Nyatha Nyatha is offline
Default I want to run my Natural Gas Generator off of Propane. What do I need to know?
Generator: Kohler 5RMY62 4.5KW set up for Natural Gas.
Model: 5RMY62
Spec: 87706-62N
Serial: 190115
I'm sure someone has done this lots... I just don't know anything about
the differences between the two gasses and what I need to change to get it
to run on propane...
Pictures are the night I brought it home and clamped it to a rollaround cart. It looks a lot better after I cleaned it...
Old 04-07-2012, 10:37:06 PM
Default Here are thos Pictures which didnt post originally...
---------- Post added at 07:37 PM ---------- Previous post was at 07:34 PM ----------
Ugh! one more try with those pics... I wonder why they wont post??! I'm using the little picture icon to get the URL from the site where they are hosted...
[IMG]http://www.flickr.com/photos/23678808@N08/6909337630/
http://www.flickr.com/photos/23678808@N08/7055427439/
http://www.flickr.com/photos/23678808@N08/7055427359/[/IMG]
Old 04-07-2012, 11:00:32 PM
Default Re: I want to run my Natural Gas Generator off of Propane. What do I need to know?
Looks like you just need to supply it with low pressure LP vapor. The mixture might need adjusting slightly and also may need to adjust the timing a little bit advanced.
Old 04-08-2012, 12:08:32 AM
I hooked it up to a BBQ sized Propane tank today and tried to start it up... it kinda just chugs then dies...
Old 04-08-2012, 10:22:03 AM
bitsnpieces1 bitsnpieces1 is offline
I believe the conversion would need a different sized jet (due to different energy densities), and possibly a different regulator (mainly due to compatible inner parts- diagphrams). Gas hot water heaters use different jets for natural gas or LP gas. Les
Old 04-08-2012, 10:25:57 AM
what type of demand regulator is on your generator?
There may be a simple swap of the input spring to swap from natural to LP.
Old 04-08-2012, 11:24:39 AM
LWB250 LWB250 is offline
No changes are necessary to the mixer or regulator. You need to have a demand (pancake) regulator with 4-6 ounces of pressure or 7-11" of water column coming into it and that's about it. Looks like everything is there for the system to work - just make sure you've got the correct inlet pressure to the fuel solenoid - if it's too high the regulator will lock off, that is, not pass any fuel.
The smaller units don't require any changes other than minor adjustments for load and that's it.
Dan
The Following User Says Thank You to LWB250 For This Post:
Converting Propane to Natural Gas cmitchell03 Onan Generators 8 10-25-2011 10:25:29 PM
Natural Gas or Propane Billy J Shafer Onan Generators 13 01-26-2009 09:23:40 PM
Propane vs. Natural Gas lijobi Onan Generators 14 12-24-2008 03:07:28 PM
Propane to natural gas... Paul Morrison Generators & Electric Motors General Discussion 8 08-19-2008 12:33:52 AM
Natural Gas to Propane ameads Onan Generators 1 09-25-2006 07:44:25 PM
