Just can,t have one
this thread has 2 replies and has been viewed 1316 times
Old 10-03-2009, 07:04:25 PM
turnwaldw turnwaldw is offline
Default Just can,t have one
Look what followed use home today from Ind today like I said can,t just have one. I will be still working on the IHC 1 1/2hp M but this way I have a runner to play with. It needs the tank cleaned out But I have and external tank next to it right know and she seems to run ok Ser #296740FW if I,m right its a 1923 Economy I dont know what the FW stand for.
Somebody went to alot of work to have somethings brass plates so I got some shinning up to do or maybe con the wife into it.
ID:	64132   Click image for larger version
ID:	64133   Click image for larger version
The Following 3 Users Say Thank You to turnwaldw For This Post:
Old 10-03-2009, 09:34:02 PM
Default Re: Just can,t have one
Yes, it's somewhat like some older religious perks, you can have more than one.
Old 10-03-2009, 11:55:30 PM
M&WJOE M&WJOE is offline
Thumbs up Re: Just can,t have one
Hi TURNWALDW, If you can count how many engines you have, you do not, I REPEAT YOU DO NOT have enough. You have one nice engine right there. Run it a lot and really get used to the workings of it. When you go to shows look closely at other brand engines and you will develope an appreciation of these mechanical marvels. They are all a little or a lot different from each other. Good luck and Happy hunting. M&WJoe
The Following User Says Thank You to M&WJOE For This Post:
