Go Back   SmokStak > SmokStak® Antique Engine Community > Antique Marine Engines and Outboard Motors
Antique Marine Engines and Outboard Motors Discussion on old marine engines, naptha, gas, oil or steam and vintage outboard motors.
LISTER LH150 Hydraulic Reversing Gear on SR2 Engine
this thread has 3 replies and has been viewed 5939 times
Old 08-16-2010, 10:03:08 AM
Rosemount Rosemount is offline
Default LISTER LH150 Hydraulic Reversing Gear on SR2 Engine
hello All ! I've got a canal narrow boat fitted with a Lister SR2 engine and LH150 gearbox . When we bought the boat last year it hadn't moved for about four years , and the gearbox had water intrusion ( possibly through the dipstick which sits low in the bilge. ) and the gearbox was stuck in "forward" , with no neutral or reverse .
I flushed the gearbox and changed the oil , and eventually called in a local marine mechanic , who sorted the problem .
We had a few days out on the boat in May / June , and now the problem has returned ( no neutral or reverse ) - I've topped the lubricant levels correctly and set the "Ahead Adjustment" screw in the gearbox to the recommended spacing , has anyone out there any advice before I phone the mechanic ($$$) again ?
*note - this is a hydraulic gearbox , and works using pressure .
Old 08-16-2010, 10:50:13 AM
Roland Hayes Roland Hayes is offline
Default Re: LISTER LH150 Hydraulic Reversing Gear on SR2 Engine
Hello there, I have the instruction book and parts list for the SRM 1,2 &3 cylinder engines by Lister Blackstone Marine Limited. It has full instructions on maintenance and adjustments of the Lister Reversing gear as well as detailed exploded veiws of the gearbox in the parts list section. Send me a private message with your address etc. and I'll send it to you. Warm regards Roland
Old 08-18-2010, 06:32:07 AM
many thanks for your reply Roland , I have the instruction manual (book number 1029/470 ) types LRM & SRM 1-2-3 cylinders , and I have followed the maintenance / trouble shooting instructions , however - no joy ! I'm going to have one more crack at it today whilst the weather's good then try a local Lister specialist my neighbour has recommended . Again , many thanks ...
Old 08-19-2010, 12:48:22 PM
ah ha ... NO OIL PRESSURE ! now faced with having to take the gearbox out and checking the pump etc .. and pos send it away to get reconned $$$ (sic) oh well bang goes the summer !
Reversing block Tony B. Steam Stationary Engines, Traction Engines 35 04-05-2013 09:57:13 PM
Lister SR2 Reversing Rotation arbgeoff Vintage Diesel and Oil Stationary Engines 11 07-14-2010 06:15:10 PM
Putting a hydraulic pump on my Lister Fe-Wood Vintage Diesel and Oil Stationary Engines 10 03-22-2010 08:45:37 PM
Reversing Generator Rotation Harvey Teal Generators & Electric Motors General Discussion 5 04-13-2009 06:55:42 PM
Reversing a Galloway Rick Strobel Hit & Miss Gas Engine Discussion 1 08-17-2006 08:43:54 PM
