What does this Brass Valve fit?
this thread has 4 replies and has been viewed 920 times
Old 03-27-2018, 07:01:58 PM
forney00c forney00c is offline
Default What does this Brass Valve fit?
I recently bought a brass valve that I can't identify. It is an International valve with 2 part numbers. The outside of the valve is 2356 D and the inside is 2357 D. While trying to figure out what it is, I bought an LB with one for the hopper drain, so I thought that's what it may be from.
I started looking through my LB manual as well as my EC-1-A manual and didn't find anything at all on the valve in the illustrations or the part number lists. Does anyone know what it goes to, or maybe even have some literature showing it? Thanks in advance for any insight!
Old 03-27-2018, 09:25:55 PM
Tom Gosciminski Tom Gosciminski is offline
Default Re: What does this brass valve fit?
IHC LA LB vacuum pump Engine fitting
The Following User Says Thank You to Tom Gosciminski For This Post:
Old 03-28-2018, 06:04:14 AM
Default Re: What does this Brass Valve fit?
So this is a drain for the LA/LB, but only for the milker engines? I wonder why that valve wouldn't be in the LB manual or EC-1-A. The only thing I see in the manual is a plain pipe plug like the generic LA/LB engines have.
Old 03-28-2018, 01:27:30 PM
Chances are it is for sanitary reasons. The drained water can be caught in a pan or bucket, not dumped on the floor of the milkhouse. no such concerns with the standard engine.
Old 03-28-2018, 10:51:16 PM
Justin Woodard Justin Woodard is offline
Hi All,
Andy is on the right track. It was for draining the hot water to clean the
milkers and the cream separator. The parts are in the book for the milker
pump setup and parts manuals.
Justin
Brass Kerosene and Gas Valve David Sundry The Junque Drawer 1 09-03-2015 07:28:30 PM
Unique Brass Valve Mike G Oil Field Engines & Related Equipment 7 12-27-2011 02:48:58 PM
Can you identify this brass valve? Todd Wilson Unidentified Engines 1 07-03-2010 10:42:03 PM
Paint removal on Brass valve Eric M. Hit & Miss Gas Engine Discussion 5 07-01-2007 08:03:30 PM
Brass fuel selector valve/bowl BWegher Hit & Miss Gas Engine Discussion 3 09-12-2005 05:59:26 PM
