Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Steam Stationary Engines, Traction Engines > Steam Gauges and Whistles
Steam Gauges and Whistles Antique steam gauges and whistles.
Needing Valve for Crosby 6" Whistle
this thread has 5 replies and has been viewed 263 times
Old 11-14-2019, 02:31:17 PM
3HorseRocky's Avatar
3HorseRocky 3HorseRocky is offline
Default Needing Valve for Crosby 6" Whistle
I tried posting in the "Wanted" ads, but I couldn't. I figured this may be the next best place. I bought a Crosby 6" Whistle and it is missing the valve. Does anybody have any good leads, or perhaps a valve that I could buy?
Old 11-15-2019, 10:29:24 AM
GreasyIron GreasyIron is offline
Default Re: Needing Valve for Crosby 6" Whistle
Is that going on a traction engine? If so I'll assume 6" tall rather than diameter. So you have a 1/2" maybe 3/4" NPT inlet?
I've only had originals so far, but both Lunkenheimer and United Brass make them, and should be easy to find new or used in those sizes.
Else, as you're probably already checking: Ebay may surface something original - even a whistle with heavy damage, but good looking valve may do for you.
In a pinch you can spring load a ball valve, but tough to make it look original. Also, hard to make that rotation as quick acting as the globe seat without a requiring some stiff pull against the spring.
What glitch did the EngineAds listing give you?
Old 11-15-2019, 01:07:05 PM
Bahahaha! That's where you're wrong! It's a 6" Diameter Whistle I bought off of the Pete Warzynski Auction by Nixon Auctioneers. Gib brought it up for my wedding.
It appears to be a 1.5" thread opening. I guess the valves were separate on the "railroad whistles " than the smaller ones. Even just trying to find a generic valve this large has been a pain!
I'm not quite sure as far as the "wanted ad" went, but it didn't give me a place to post or make a new thread even after refreshing a few times.
The Following User Says Thank You to 3HorseRocky For This Post:
Old 11-15-2019, 02:38:35 PM
A 6" whistle and you didn't post pictures?! I didn't follow the auction, but I suspect that means that a little sticker shock on the valve should be small potatoes. With Jowetts down your way, you could double check, but I don't think UBW goes that big on a whistle valve. Lunkenheimer should be available yet.
IIRC, you need to separately log in to EngineAds, even if logged into smokstak with the same credentials, or you won't see the buttons to create a new ad.
Old 11-18-2019, 02:01:14 AM
Yeah yeah, I need to get savvy on this forum lol
After doing some real measuring and test fitting, it is in fact a 1 1/4 fitting, however; it also would appear this whistle DOES in fact have a built in valve, but it is missing all of its internals. So, I have the option to try to piece a valve assembly together, or find something to thread on in a pinch for the time being. Although I paid handsomely for the whistle, I will admit that I was still a bit floored when looking at valve prices. It should be a bit better now that I'm looking a "tad" smaller, but it's not going to help the ole wallet very much!
I did go ahead and try to upload a pic. Its not the best as it was a quick shot for a friend of mine while it was sitting in my truck! But that should at least satisfy you somewhat lol
Old 11-22-2019, 03:51:09 PM
Pete LaBelle Pete LaBelle is offline
Before you look into a new valve, can a valve be made for the one you have? Most likely, the old valve got too leaky and the operator couldn't grind it to seat, thus replaced it with a new valve up stream. So long as the valve seats haven't been damaged, a new valve spool, spring, fulcrum & handle and it'll perform as new. This, provided you, or a friend, can do some machining.
Yes, larger valves are commanding larger dollars. Welcome to the financial strains of collecting whistles !
The Following User Says Thank You to Pete LaBelle For This Post:
My New 10-inch Diameter Crosby Steam Whistle StationarySteam Steam Stationary Engines, Traction Engines 14 12-24-2014 01:21:36 PM
Crosby 3 Chime Whistle B. Riley Steam Stationary Engines, Traction Engines 7 05-11-2014 04:46:33 PM
3/8" United Brass Works Whistle Valve Question cyberbadger Steam Stationary Engines, Traction Engines 16 04-15-2013 06:25:33 PM
Where to buy 1 1/4" Whistle valve JoeCor Steam Stationary Engines, Traction Engines 4 01-17-2013 01:37:56 PM
1-1/4" whistle valve source? Allen Steam Stationary Engines, Traction Engines 4 08-01-2008 07:16:51 PM
