Steam Engines
Steam Stationary Engines, Traction Engines Antique steam engines, their boilers, pumps, gauges, whistles and other related things that make them run. Also Locomotives nad Railroads.
Lambert hoist engine converted to traction project
this thread has 207 replies and has been viewed 46893 times
Old 02-23-2014, 01:17:24 PM
K.O'Connell's Avatar
K.O'Connell K.O'Connell is offline
Default Re: Lambert hoist engine converted to traction project
I can't help but think that cylinder had wood lagging and a jacket at one time.
Old 02-24-2014, 01:49:18 AM
John T Hall John T Hall is offline
I might put a jacket on the cylinder. OK I put in a long day. Took one shim out of the cross head slide after it was installed and it slides good. This engine has the Stevenson valve gear. Part of the linkage was built in the hoist frame but I was able to use it. I had to make a stand to mount it on top of the boiler. The Gaar Scott big 40 has a clear view of this set up on u tube that was used as a guide. I had strings hanging from the floor joist to hold it while using a level and square to tack it together. It is home made looking but I think I can get it better. The Datona 500 was ran today but missed it.
ID:	188852   Click image for larger version
ID:	188853   Click image for larger version
ID:	188854   Click image for larger version
The Following 4 Users Say Thank You to John T Hall For This Post:
  #63
Old 02-25-2014, 08:36:05 PM
Boxed in that valve gear and smoothed up the edges. It looks more like a casting now. Putting on a quadrant shelf seemed to be the next step. I found this old set of wore out bolt cutters at the local antique shop. Are you thinking what I'm thinking?
ID:	189016   Click image for larger version
ID:	189017   Click image for larger version
ID:	189018   Click image for larger version
  #64
Old 02-26-2014, 06:50:45 AM
Peter Peter is offline
I have some questions about this setup. I marked up the picture below.
1. Is is good idea to use teflon ball valve for hi pressure steam? Seems the traditional setup has been some kind of brass seat gate. I know some modern whislte valves use teflon.
2. That valve looks light for steam. Although i think I can make out 125psi. it seem light for traction duty. They seem they used a lot more brass on the stuff I am used to seeing. What is your planned max pressure?
3. These are all questions and not meant as critical. I have several of those cast iron balls. I have asked and never got a reply on this forum. Mine all come from 15psi heating boilers. Are those ok for high pressure and traction vibration? Used to seeing a pigtail, or special cast bronze traps. cattail has some reproductions.
4. A suggestion. I know a direct connect was typical in the old days (not elbow and nipple though) , but seems a more modern / code approach would be a globe shutoff at every steam nipple.
The Following User Says Thank You to Peter For This Post:
  #65
Old 02-26-2014, 09:58:12 AM
David's Avatar
David David is offline
I would have thought this too, but when the Tennessee Valley RR kept having trouble with the starting valves on one of their engine, they installed a ball valve with a Teflon seat, 2" NPT.
On a standard gauge locomotive, you use the injector frequently for short periods of time, and in a day, it would not be unusual to use the ball valve 50-60 times.
It lasted for years, and gave good, trouble-free service, and made a believer out of me and TVRM.
The operating pressure was 205 psi.
David
The Following User Says Thank You to David For This Post:
  #66
Old 02-26-2014, 10:41:14 AM
Teflon is good for 450 deg F, and with the "low pressure" steam most of us run, it's well within the temp range of Teflon.
Mike
The Following User Says Thank You to Mike McKnight For This Post:
  #67
Old 02-26-2014, 07:43:46 PM
Dale Miner Dale Miner is offline
My 1/2 scale has a ball valve for a throttle, and has given trouble free service flr over 30 years. Teflon seats and 150 psi operating pressure.
The Following User Says Thank You to Dale Miner For This Post:
  #68
Old 02-27-2014, 09:26:37 PM
Dumped the scrap iron barrel over and found Mower deck spring. Drive shaft u joint cups. Chain saw rivet pliers handle. 2 cold shut chain repair links. Then add bolt cutters and a lambert water meter lid from E bay and you get a reversing quadrant. I'll cut the notches in when I time the valve gear.
ID:	189203   Click image for larger version
ID:	189204   Click image for larger version
ID:	189205   Click image for larger version
The Following 6 Users Say Thank You to John T Hall For This Post:
  #69
Old 02-27-2014, 09:56:43 PM
BlkBeard BlkBeard is offline
Were you a Ghost Writer for Mcguyver in a former life?
Old 02-27-2014, 10:26:40 PM
Well the secrets out now. funny thing is 95% of the general public will think the whole engine is factory.
Old 02-27-2014, 10:34:47 PM
It looks like it's coming along very nicely
The Following User Says Thank You to BlkBeard For This Post:
  #72
Old 03-01-2014, 12:49:07 AM
The steam chest has a 1-1/4" inlet so when I saw this governor on E bay a few weeks ago I got it. I'm starting on it now. Its wore out and has parts missing but nothing that cant be fixed. The upper gear was worn on the shaft so bad it would not mesh with the pulley gear. Drilled over size and bushed it was the first step. Early patent date.
ID:	189329   Click image for larger version
ID:	189330   Click image for larger version
ID:	189331   Click image for larger version
The Following 2 Users Say Thank You to John T Hall For This Post:
  #73
Old 03-01-2014, 02:32:03 AM
16GaarScott's Avatar
16GaarScott 16GaarScott is offline
You are sure moving right along, keep the photos coming!
Old 03-01-2014, 11:14:10 PM
The governor had some speed adjustment parts missing. Blkbeard your going to like this one. Look what I used for the missing worm. It meshes perfectly. I know most of you gentlemen have guess it. The other end is off a sprung C clamp.
The Following 5 Users Say Thank You to John T Hall For This Post:
  #75
Old 03-02-2014, 09:09:03 AM
Talking Re: Lambert hoist engine converted to traction project
............Checking my toolbox, and counting my Crescent Wrenches
Old 03-02-2014, 09:30:52 AM
Very clever. I always enjoy seeing this type of thinking. And it looks right.
The Following 4 Users Say Thank You to Peter For This Post:
  #77
Old 03-02-2014, 01:30:32 PM
JEngines JEngines is offline
I have an original thumbscrew. More than happy to donate to a good cause. Any other governor parts missing?
Name:	thumb Screw.JPG
Old 03-02-2014, 01:34:18 PM
The Thumbscrew may be off an older Pickering. don't know if it will fit.
Old 03-02-2014, 07:27:25 PM
Thanks for the offer but I think I got it. One side of the leaf spring was gone so I cut some strips out of a hand saw for both sides. We will see how it works when its running but it springs back nice every time with new packing. With a pair of balls this big the engine might try to pull a 40x66 separator. better try a pea huller first.
ID:	189494   Click image for larger version
ID:	189495   Click image for larger version
ID:	189496   Click image for larger version
The Following 8 Users Say Thank You to John T Hall For This Post:
  #80
Old 03-02-2014, 07:41:44 PM
wagswitte wagswitte is offline
Looking good John can't wait to see a video of it puffing some smoke and steam keep up the great work.
The Following User Says Thank You to wagswitte For This Post:
Portable converted to traction engine? David Parfitt Steam Stationary Engines, Traction Engines 13 01-22-2010 01:03:18 AM
Car Hoist Project - Do I Have Enough Power? J. McNugget Generators & Electric Motors General Discussion 8 12-29-2006 11:25:54 PM
Lambert Hoist & Engine Co. Bruce Wambach Steam Stationary Engines, Traction Engines 4 12-15-2004 01:28:47 PM
Steam traction engine project pic Andrew Steam Stationary Engines, Traction Engines 0 11-28-2003 12:10:09 AM
Steam traction engine project pic Andrew Steam Stationary Engines, Traction Engines 0 09-29-2003 01:24:24 AM
