Steam Engines
Steam Stationary Engines, Traction Engines Antique steam engines, their boilers, pumps, gauges, whistles and other related things that make them run. Also Locomotives nad Railroads.
Advances are Absolutely Awesome
this thread has 238 replies and has been viewed 51203 times
Old 04-05-2015, 04:52:55 PM
Reeves13hp's Avatar
Reeves13hp Reeves13hp is offline
Default Re: Advances are Absolutely Awesome
Heres a picture of a 18hp Advance wheel that i bored out. It was an earlier engine than the 16hp so it didnt have the sleeved wheels.
8-1/2x10 Frick
13hp Reeves
50hp Case
22hp Wood Brothers
18hp Advance
20-75 Nichols & Shepard
20hp Corner Bracket Advance
16hp Minneapolis
The Following 6 Users Say Thank You to Reeves13hp For This Post:
Old 05-10-2015, 10:53:28 PM
LundMachineWorks LundMachineWorks is offline
35 Advance with a new crankshaft (the original was bent), built-up crank pinion, and intermediate gears.
ID:	225222   Click image for larger version
Jeff Lund
Lund Machine Works
www.lundmachine.com
Old 05-11-2015, 02:53:15 PM
30Advance's Avatar
30Advance 30Advance is offline
Jeff,
Did anyone ever scale that engine full of water and fuel and see what it's working weight was? Sure be fun to know.
She's a Beast! What is the MAWP now?
Thanks,
Dave
Old 05-11-2015, 04:59:43 PM
I will ask, I believe he scaled it when he hauled it home, but I do not know. Just driving it make the ground shake. It has a 125 mawp. The whole boiler is 7/16 except for one plate in the firebox is 5/16" which limits it.
They weighed it dry with a few pieces missing and dry at 36,000. It seems to take about 500 gallons to fill the boiler (based on time to fill).
Jeff Lund
Lund Machine Works
www.lundmachine.com
The Following 2 Users Say Thank You to LundMachineWorks For This Post:
  #225
Old 05-15-2015, 11:16:43 AM
30Advance's Avatar
Jeff,
That would make her about 2500 lbs. heavier than my 30 Cross Compound! Do you know if Mark Pederson ever weighed the big 40 Advance CC?
Dave
Old 07-21-2017, 10:32:23 AM
Casemaker Casemaker is offline
see the video below... I was wondering if this is a 12hp and who owns it ? Looking at some other clips posted by the same individual it might be Washington state ?
https://www.youtube.com/watch?v=c94sPIl5J-k
The Following 2 Users Say Thank You to Casemaker For This Post:
  #227
Old 07-21-2017, 11:36:45 AM
JBoogie's Avatar
JBoogie JBoogie is offline
That's a real neat early Advance. Boiler is interesting......
Old 07-22-2017, 02:15:09 PM
Ryan Williams Ryan Williams is offline
Glad you like the engine! As it so happens, that is my video (and my channel).
I don't remember 100% for sure, but I believe the engine is a 10hp model from 1890. It is owned by Gary Miller of Yacolt, Washington. The video is from last year when we had just finished putting the engine back together with its brand new boiler with the help of Alan Schurman. The engine still has some quirks that need to be worked out of it (such as when the throttle flopped over and stuck open at 7:57 in the video), but it is up and running. And don't worry, the timing is much better now.
Here's a picture of it running at our show just last weekend at Schurman's Iron Ranch. Sorry if it's not much of a picture but we were laughing about some pitch filled wood we had just gotten into and wishing we had some coal. Mr. Miller also has a 16hp Advance that we will hopefully begin restoring soon as well.
By the way, those of you coming to the Great Oregon Steam Up in Brooks, Oregon might get a chance to see the 10hp in person. We're working on it ...
Name:	10hp advance smoke.jpg
ID:	286913   Click image for larger version
Name:	16hp advance.jpg
The Following 4 Users Say Thank You to Ryan Williams For This Post:
  #229
Old 07-22-2017, 09:53:45 PM
Ryan,
do know approximate weight ? I thought i read where the early, square style cleats were used until 1900 ? Does anyone know this for a fact ?
Old 07-22-2017, 11:25:16 PM
Ryan,
We talked about the weight a while back. I want to say we settled on around 10k dry. I have no idea on the cleats...
Old 07-23-2017, 06:57:57 PM
Nik O. Nik O. is offline
1902...be blessed, grateful, prepared...
Old 07-23-2017, 08:11:06 PM
I know of a 1904 that has the square style cleats...it is a 12hp and i realize the wheels could have been swapped or built before the engine was assembled.
Old 07-24-2017, 12:07:15 PM
anthony k axsom anthony k axsom is offline
How did you get the crank disk off? All ways been told they were pressed on.
Old 07-25-2017, 01:52:32 AM
Heat and press it back off?... That's what I'd assume Lund did. Hardest part is just setting it up in the press.
Old 10-15-2017, 01:20:16 PM
greysteam24hp's Avatar
greysteam24hp greysteam24hp is offline
Posting an interesting group of vintage steam photos. I knew I have found it last year. Here are the 4 photos the same sister Advance engine picture taken near Muir Michigan, I provided a links from their PDF file site because you can click super enlarge picture to view close up pictures! First photo has front wheel removed in order to have room for belt....
Four links below. Click link then click on photo to super size to view...
http://riblakehistory.com/Rib%20Lake...log%20deck.jpg
http://riblakehistory.com/Rib%20Lake...0in%20open.jpg
http://riblakehistory.com/Rib%20Lake...in%20woods.jpg
http://riblakehistory.com/Rib%20Lake...0operation.jpg
---------- Post added at 01:20:16 PM ---------- Previous post was at 01:17:50 PM ----------
Notice I see white water marks on back head and the wrapper boiler. Must be bad water up there? Cant see the pop valve ...
The Following 3 Users Say Thank You to greysteam24hp For This Post:
  #236
Old 05-29-2018, 01:24:01 PM
Steamrguy's Avatar
Steamrguy Steamrguy is offline
Gary and Dave
I just spent two day running this 22 Advance. I do not know if you remember this engine or not. It came out of the Christenson place near Conrad about 1980. It has not been out in many years now. Still a good running engine! A lot of fun!
Dean
Name:	Advance 22 At the best show 1.jpg
ID:	311427   Click image for larger version
Name:	Advance 22 At the best show 2.jpg
The Following 5 Users Say Thank You to Steamrguy For This Post:
  #237
Old 05-29-2018, 03:32:45 PM
30Advance's Avatar
Dean,
I was at that sale but I don't remember ever seeing that engine. I do remember someone telling me that they had one or two steamers but I think they were sold before the actual sale. There sure was a few high-dollar gas tractors there! I don't know where any of that stuff ended up.
Dave
The Following User Says Thank You to 30Advance For This Post:
  #238
Old 09-23-2018, 09:33:45 AM
forney00c forney00c is offline
This weekend, we steamed up our 22 HP Advance Rumely one more time before winterizing it, along with our A.J. Goodban locomotive.
ID:	319351   Click image for larger version
The Following 4 Users Say Thank You to forney00c For This Post:
  #239
Old 02-26-2019, 10:54:07 PM
Brad Kelley Brad Kelley is offline
Who's the girl on the back of this Advance catalog?
The Following User Says Thank You to Brad Kelley For This Post:
Absolutely awesome models Thaumaturge Scale Model Engineering 1 01-06-2017 11:56:43 PM
Colin Advances Another Year Beth V Steam Stationary Engines, Traction Engines 5 07-15-2011 09:40:52 AM
