6 Horsepower Flinchbaugh York Engine
this thread has 58 replies and has been viewed 9096 times
Old 02-17-2019, 04:54:10 PM
Harry Terpstra Harry Terpstra is offline
Default Re: 6 hp York
Time to make some patterns of parts I need to have cast. Fortunately a friendly collector with another 6 hp York gave me all the dimensions for the piston and con-rod. The piston is extremely long 11.125". A friend glued together a block of wood sheets. Over the weekend I machined a wooden piston out of it. It is about 5/16" oversize to compensate for shrinkage and I rather machine off a lot than have not enough material.
Name:	- 1 (169).jpg
ID:	328839   Click image for larger version
Name:	- 1 (168).jpg
ID:	328840   Click image for larger version
Name:	- 1 (170).jpg
Old 02-17-2019, 05:23:56 PM
I also made a pattern for the big-end bearing block. I will have it cast in one piece.
Name:	- 1 (171).jpg
ID:	328842   Click image for larger version
Name:	- 1 (172).jpg
ID:	328843   Click image for larger version
Name:	- 1 (167).jpg
Old 02-17-2019, 06:09:10 PM
Dale Russell Dale Russell is online now
Harry, where there is a will, there is a way! Have fun. You must feel a huge amount of accomplishment when you hear a case like this run for the first time.
The Following 3 Users Say Thank You to Dale Russell For This Post:
  #44
Old 02-22-2019, 06:13:40 PM
I need some thoughts on this:
I need to make a new 3" 8tpi plug in the front of the combustion chamber as I sawed the old one out. Should it be made from cast iron so it is the same material as the cylinder / combustion chamber, or would steel work as well. I was thinking since a steel spark plug seals well in either a steel cylinder head, and even an aluminum head, so I think a steel plug will work fine.
Any idea's?
Old 02-22-2019, 08:24:18 PM
Steel would work fine but cast iron was original so I would make a cast plug.
  #46
Old 02-23-2019, 03:44:19 AM
You are right about that Bill, although it will be invisible (it's behind the cover plate) I agree cast iron is original. It will probably also rust less than steel.
Old 02-25-2019, 09:39:32 PM
ohiomotorco ohiomotorco is offline
Default Re: 6 Horsepower Flinchbaugh York Engine
Is the plug a tapered pipe plug? I have access to cast iron tapered pipe plugs made in a couple configurations, and would be happy to obtain one for you.
3" NPT plugs are 8 TPI
Old 02-26-2019, 12:44:00 AM
Yes it is a tapered pipe plug. I got a 3" BSP plug here but it turned out to have the wrong pitch (11') I didn't check before I got it. It also was hollow on the back side. The original was flat on the cylinder side. If you could check out for me if they are flat on the back side. If so I would appreciate your offer to get one.
Old 03-13-2019, 11:24:47 PM
Harry,
I sent you a PM tonight, hopefully the photo of the plug is attached. It is completely flat on the bottom , with a 1-1/2" recessed square on the face for install.
Karl
The Following User Says Thank You to ohiomotorco For This Post:
  #50
Old 03-16-2019, 12:25:06 PM
The surface of the exhaust valve box on the cylinder casting was rotted pretty bad. My first idea was to just clean it out thoroughly and fill the holes with JB weld, however I wasn't happy with the JB weld and at second thought I decided it wasn't the right way to do. So I took the cylinder back to my work and made a set up to attach it to the mill.
Name:	- 1 (174).jpg
ID:	330706   Click image for larger version
Name:	- 1 (175).jpg
ID:	330707   Click image for larger version
Name:	- 1 (177).jpg
The Following 4 Users Say Thank You to Harry Terpstra For This Post:
  #51
Old 03-16-2019, 12:37:39 PM
After lining everything out it took only a few passes to get a clean and flat surface. Of course the valve box was also cleaned up. New 5/8" 12 TPI studs are made.
Name:	- 1 (176).jpg
ID:	330709   Click image for larger version
Name:	- 1 (175).jpg
ID:	330710   Click image for larger version
Name:	- 1 (180).jpg
ID:	330711   Click image for larger version
Name:	- 1 (181).jpg
The Following 11 Users Say Thank You to Harry Terpstra For This Post:
  #52
Old 03-17-2019, 08:05:49 AM
P Schmidt's Avatar
P Schmidt P Schmidt is offline
Harry, Good job !!! That is doing it the correct way. JB weld would have failed.
Paul
The Following 2 Users Say Thank You to P Schmidt For This Post:
  #53
Old 03-17-2019, 08:32:38 AM
Thanks Paul,
I agree, the JB weld solution was wrong from the beginning but it didn't hurt as it just mills away again. I saw I posted the wrong photo of the result. This is the correct photo. On the photo it looks like there are quite some marks, but with the eye it's barely noticeable.
Name:	- 1 (182).jpg
  #54
Old 03-18-2019, 04:46:49 PM
Making 8 new 5/8" x 3 1/4" high-crown bolts. I'm going through a full length 1-1/16" hexagon bar just for the 8 bolts and a few nuts.
Name:	- 1 (183).jpg
The Following 8 Users Say Thank You to Harry Terpstra For This Post:
  #55
Old 06-13-2019, 04:53:21 PM
I am very happy that the previous owner in Australia found the original rod, and one half bearing shell and also the original piston. Even better, they were able to bring it to the Nuenen show where I got it.
I wonder what the letters R B mean. My guess is that the rod was made by a specialized supplier.
Name:	- 1 (200).jpg
ID:	337075   Click image for larger version
Name:	- 1 (201).jpg
ID:	337076   Click image for larger version
Name:	- 1 (202).jpg
ID:	337077   Click image for larger version
Name:	- 1 (203).jpg
  #56
Old 06-13-2019, 08:13:47 PM
Jeremy Hartle Jeremy Hartle is offline
You lucky dog. Better go buy a lottery ticket.
The Following User Says Thank You to Jeremy Hartle For This Post:
  #57
Old 06-15-2019, 03:34:41 PM
The last big parts that needed a electrolysis treatment were the flywheels with the crankshaft. Clearly visible after a thorough clean-up are the marks of machining the outside of the flywheel. As seen in the last picture the inside of the flywheel is not machined. I don't know if it was common practice to machine the outside of the flywheels for some engine factories.
Name:	- 1 (204).jpg
ID:	337206   Click image for larger version
Name:	- 1 (205).jpg
ID:	337207   Click image for larger version
Name:	- 1 (206).jpg
ID:	337208   Click image for larger version
Name:	- 1 (207).jpg
The Following 6 Users Say Thank You to Harry Terpstra For This Post:
  #58
Old 06-30-2019, 03:26:11 AM
The cam was worn quite bad so I decided to replace it. I machined the worn cam-lobe from the gear, and had a a new cam plasma cut and told them to keep the hole smaller so I was able to machine it out to make a shrink fit. Of course they did cut the hole as well, and it wasn't exactly a tight fit. So I welded up the hole and after some time consuming setting up in the 4 jaw chuck I machined is out to just under size.
Name:	- 1 (208).jpg
ID:	338188   Click image for larger version
Name:	- 1 (209).jpg
ID:	338189   Click image for larger version
Name:	- 1 (210).jpg
ID:	338190   Click image for larger version
Name:	- 1 (211).jpg
  #59
Old 06-30-2019, 03:40:40 AM
I put the gear in the freezer for a couple of days. Then I heated the cam and slid it on the gear. Although it is very stuck on just the shrink fit, I decided to put in some set screws just to be sure.
Name:	- 1 (213).jpg
ID:	338192   Click image for larger version
Name:	- 1 (214).jpg
ID:	338193   Click image for larger version
Name:	- 1 (215).jpg
ID:	338194   Click image for larger version
Name:	- 1 (216).jpg
1 1/2hp York Flinchbaugh Engine IHCMatt Antique Gas Engine Discussion 1 08-27-2015 06:07:08 PM
Flinchbaugh-York Gene Fisher Antique Gas Engine Discussion 1 02-06-2015 09:46:35 PM
York Flinchbaugh 1.5 hp ironengineman400 Antique Gas Engine Discussion 9 12-05-2009 02:34:25 PM
Flinchbaugh/York Tractors Eric Best Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 6 05-06-2008 06:47:12 AM
Flinchbaugh engines from York, PA JamieWF Antique Gas Engine Discussion 5 06-05-2007 07:32:07 AM
