Wisconsin Engines
Please Help me Identify this Wisconsin
this thread has 6 replies and has been viewed 1799 times
Old 05-15-2012, 06:38:47 PM
Bigjoedo's Avatar
Bigjoedo Bigjoedo is offline
Images: 21
Default Please Help me Identify this Wisconsin
Looking at this Wisconsin engine. Can anyone tell me what model it might be and if parts are still available. Thanks
Bigjoedo
I cleaned a lot of the grease and crap off, behind the flywheel I found AA-35 or it could be AA-65 or AA- 95 can't make out the first number. It has a F&M magneto and 8 head bolts. Cleaned the points and it has a hot blue spark.
Looking at the unofficial Wisconsin engine website I found this info
AA
Bore & Stroke 2-1/4 X 2-3/4
HP 1.8 @ 2600
Years Produced 1936 - 1949
L-Head Mechanical Governor Outboard Magneto
Is this the engine I have? Is it worth $75? Where can I buy a Gas tank, Carburetor Muffler etc? Thanks
Name:	photo 1 smaller.jpg
ID:	135428   Click image for larger version
Name:	photo 2 smaller.jpg
ID:	135429   Click image for larger version
Name:	photo 3 smaller.jpg
ID:	135430   Click image for larger version
Name:	photo 4 smaller.jpg
Old 05-16-2012, 09:21:31 AM
Homebrewer Homebrewer is offline
Default Re: Please Help me Identify this Wisconsin
I am not by any way an expert. But it looks like some parts would interchange with my BKND, but looks older maybe a BKN, it is hard to tell, a lot of parts missing. I assume there is no tag on the shroud?
The Following User Says Thank You to Homebrewer For This Post:
Old 05-16-2012, 11:02:50 AM
KenHilliard KenHilliard is offline
I would not but the engine. It looks pretty well parted out. Used carb and manifold will be about 50 at least. Air cleaner the same. Gas tank and bracket, if found, maybe twenty. There two major questions. The mag's condition and if it doesn't work you can get a whole running engine for a lot less than the cost of its rebuild. The missing plug means that the cylinder is at best badly containinated if not seized; so that area will require a lot of work. If the mag has good, hot spark, then it it worth the $75 if you locate another complete engine.
The vertical plug suggests an acn or bkn. The ab's and akn's have the slanted plug.
The Following User Says Thank You to KenHilliard For This Post:
Old 05-16-2012, 11:38:50 AM
Bigjoedo's Avatar
Images: 21
Ken,
The mag has a good hot spark, engine turns over fine and has good compression. It looks like parts may be hard to find. So basicly at best it is a parts engine? Thanks
Bigjoedo
Old 05-16-2012, 06:41:28 PM
Zira Zira is offline
First, the casting number you posted is not the model number. It looks like your engine is an ACN or BKN. These are pretty common and not as old as the AA. Parts for this are not that hard to find, but the zenith carb's that most used are very prone to corrosion problems inside. If you can get it cheap it is a good engine to play with. I wouldn't pay much for it though. It would not be be worth $75 if complete & running in that cosmetic condition. If you did get it I can help you with parts but there are a lot of these in the $30 - $50 range with less missing parts. And don't be afraid of bad mags, working used ones are only $20 - $25. Gas tanks, air cleaners, and carbs are at least as important.
The Following User Says Thank You to Zira For This Post:
Old 05-16-2012, 08:18:54 PM
Bigjoedo's Avatar
Images: 21
The engine cleaned up pretty well. But is missing a lot of parts as stated. Mag is hot, head gasket is good valves look ok and move well, but it has almost no compression. 2 7/8" bore by the way. I haven't paid him and think I will take it back and tell him it would be to costly to get it looking and running well again. Thanks for the help.
Bigjoedo
Old 05-20-2012, 08:58:29 AM
magneticanomaly magneticanomaly is offline
Perhaps $75 is high, but Offer him $30.
Don't worry about availability of original parts, many carbs could be adapted to fit, as fuel tanks or make one from a piece of stovepipe.
Unless you don't NEED a sturdy, torquey, fuel-efficient, easy-starting engine that will outlive you.
Identify decal on Wisconsin tank wheelhorseboy Wisconsin Engines 0 11-29-2011 12:41:27 AM
Help to Identify Year of Wisconsin Engine wheelhorse4u Garden Tractors / Mowers / Scooters 1 08-31-2010 09:48:37 PM
Help to identify Wheel Horse Wisconsin engine wheelhorse4u Garden Tractors / Mowers / Scooters 3 08-30-2010 09:14:05 PM
Help identify a Wisconsin will s Wisconsin Engines 5 12-13-2009 01:48:26 PM
please identify genset wisconsin?? steve tyson Generators & Electric Motors General Discussion 2 12-27-2002 03:18:32 AM
