Wisconsin Engines
Help with identification
this thread has 3 replies and has been viewed 1790 times
Old 03-02-2012, 03:16:53 PM
dasratsel dasratsel is offline
Default Help with identification
Got this wisconsin engine and looking for info.
Model: AENLD
Spec #: 366575
Serial #: 5237931
Also looking for a carb rebuild kit, bendix. It leaks, and is very hard to get started. Thank you.
ID:	130170   Click image for larger version
Old 03-02-2012, 06:17:04 PM
Tencubed Tencubed is offline
Default Re: Help with identification
The AENL entered production in 1957 and was an upgrade of a general family of engines. The "D" suffix indicates the engine had a Stellite exhaust valve and probably a valve rotator.
Bore and stroke were 3" X 3 1/4", developed 9.2 HP at 3600 RPM.
Don't know when production ceased but that is a good engine. I've got a couple and they are easy to start.
For carb parts, or if you're like me and don't like working on carbs, contact Carbrescue.com and visit with Mark.
Mike
---------- Post added at 02:17 PM ---------- Previous post was at 02:14 PM ----------
Senior moment! Forgot to include this web site. Good place for information on Wisconsin engine history and tech info.
http://my.att.net/p/s/community.dll?...pid=256080&ck=
Mike
The Following User Says Thank You to Tencubed For This Post:
Old 03-02-2012, 08:56:32 PM
Zira Zira is offline
Take the numbers on the carb to a decent auto parts store, they can get a rebuild kit. The carb was used on a lot of different engines besides Wisconsin's.
The Following User Says Thank You to Zira For This Post:
Old 03-02-2012, 10:54:20 PM
Yes, runs real good when started. But I think due to the carb leak, it's getting hard to start. Had it on a home made log splitter.
Help With Identification 1908Reeves Hot Air Engines 3 12-04-2010 12:47:48 PM
Need help with identification Meco3hp Unidentified Engines 2 04-17-2009 08:47:42 AM
Help with identification on gen set please Mbrgr Onan Generators 14 02-23-2008 02:36:28 AM
Need identification help Duane H Antique Gas Engine Discussion 8 11-16-2007 08:50:41 PM
mag identification Tom Winland Antique Engine Archives 0 05-14-2003 10:29:19 PM
