Wisconsin Engines
wisconsin thd seal
this thread has 4 replies and has been viewed 1758 times
Old 03-28-2012, 10:58:10 PM
jamest jamest is offline
Default wisconsin thd seal
I have a THD that is leaking oil from the pto end. Suspect the seal is going. The book shows a cork seal. Has anyone replaced this with a later style seal with lips or will I have to find a cork seal. Any help would be appreciated
Old 03-29-2012, 05:56:16 AM
Phil P Phil P is offline
Default Re: wisconsin thd seal
Hi
I believe they are available from Wisconsin. Google the name and have a look at their web site.
Phil P
The Following User Says Thank You to Phil P For This Post:
Old 03-29-2012, 02:31:37 PM
windrush windrush is offline
On my AK Wisconsin I replaced the cork with some graphited waterpump gland packing, I split the joint at 45 degrees to get a good seal and it has worked fine for 10 years or more! If you can get the proper seal that would be better of course.
Pete.
The Following 2 Users Say Thank You to windrush For This Post:
Old 03-30-2012, 12:08:41 PM
Tencubed Tencubed is offline
I like the graphite seal Windrush mentions. Good idea IMO.
I looked at my stuff and don't have one around. Called the local Car Quest store and they don't list it but said they may be able to match by measurement. You might try this at your local Car Quest and/or NAPA.
Local store is used to me looking for old and odd stuff, I've found it helps to take in a dozen donuts from time to time. Seems they kind of like helping me.
Mike
The Following 2 Users Say Thank You to Tencubed For This Post:
Old 03-31-2012, 12:15:23 AM
Will look it up. Run Engine full speed for an hour a week running a sprayer fan and it thows 2 oz of oil or so-never did before. Will check breather but if seal would like a sure fix. Thanks for the lead
oil seal Johnnyboy Small Air Cooled Gasoline Engines 1 02-28-2011 12:38:56 AM
JD/B seal David Scott Antique Farm Tractors 2 12-09-2010 02:08:09 AM
Sgl Cyl Continental Red Seal jrc411 Unidentified Engines 3 10-07-2010 10:22:39 PM
Wisconsin TFD - Crank seal bondoo0 Wisconsin Engines 2 10-15-2009 05:22:14 PM
E Carb Seal MaytagRepairMan Maytag Engine Collectibles 3 08-19-2009 12:14:12 AM
