Wisconsin Engines
Wisconsin AEND
this thread has 5 replies and has been viewed 1819 times
Old 04-07-2012, 01:04:10 AM
Jim M. Jim M. is offline
Default Wisconsin AEND
OK guys, I'm a sucker for single cylinder Wisconsin engines and I'm thinking of bidding on Ebay Item number: 280857973222. The sheet metal looks good. The owner said it needs a coil for it's magneto and starter pulley. It looks like a Fairbanks Morse unit. Are coils still available for this magneto? Thanks, Jim
Old 04-07-2012, 01:55:20 AM
John Newman, Jr.'s Avatar
Default Re: Wisconsin AEND
If you don't get that one, I have a MAENLD (Military AENL with Stellite exhaust valve) we can discuss. Complete, except for fuel tank, but has a short shaft. Good mag & starter pulley.....
John Newman, Jr.
Saint Louis, MO
I Can Probably Fix That
Old 04-07-2012, 09:20:17 AM
Zira Zira is offline
Coils are available but expensive. Working used mags are available for ~$25 though. An AENL mag will work fine for it, or you can buy one & swap out the coil.
The Following User Says Thank You to Zira For This Post:
Old 04-15-2012, 04:31:12 AM
I will be picking up the above engine next weekend. What is the difference between an AEN and an AENL. How does the AENL pick up the extra 1HP? Thanks, Jim
Old 04-15-2012, 08:38:59 PM
Higher compression & slightly more spark advance. Pretty much all AENL parts will work on the AEN.
Old 04-16-2012, 03:36:34 PM
Tencubed Tencubed is offline
Good site for Wisconsin information.
http://my.att.net/p/s/community.dll?...pid=256080&ck=
Mike
The Following User Says Thank You to Tencubed For This Post:
Wisconsin TRA-10D John L Phillips Wisconsin Engines 2 02-04-2012 07:52:36 PM
Two cyl. Wisconsin help ID, no tag... Artyfact Wisconsin Engines 15 09-17-2011 10:33:07 PM
Hello from Wisconsin tvfd911 Smokstak Forums Meet and Greet 3 05-14-2010 02:28:16 PM
Wisconsin BKN Jim M. Wisconsin Engines 1 04-12-2010 01:23:35 AM
going to wisconsin john willis Antique Engine Archives 2 09-14-2003 09:12:12 PM
