Wisconsin Engines
Wisconsin BKND help!
this thread has 2 replies and has been viewed 1750 times
Old 05-09-2012, 10:05:56 AM
Homebrewer Homebrewer is offline
Default Wisconsin BKND help!
Hello Guys,
I am new here and this is my first post. I have been lurking around for about a week and decided I need to be a part of this group. I just bought a Waste Water Pump (CMC Brand) powered by a Wisconsin BKND at an auction. I have given it a good cleaning, took apart the carburetor (Zenith) and cleaned all the jets, actually looked good and clean inside. Cleaned the fuel tank, because the tank was a little rusty, added new fuel line and put in an inline filter. It has great compression and I have leaned a lot about a magneto, It doesn’t matter how slow you turn the engine when that magneto fires you will know if it works or not. (Knocked the crap out of me).
The question I have before I pull the rope on this too much is the rotation, know where on it do I see an arrow showing rotation but I assume it is clockwise. Can someone confirm this? And any other tips about starting this for the first time. BTW I have disconnected the trash pump for my initial run. Thanks
Old 05-09-2012, 11:03:13 AM
Tencubed Tencubed is offline
Default Re: Wisconsin BKND help!
This site has a lot of information on Wisconsin engines.
http://my.att.net/p/s/community.dll?...pid=256080&ck=
Rotation is clockwise facing the flywheel end of the crank.
Mike
Old 05-09-2012, 11:51:27 AM
Thank You!!!
Wisconsin BKND mbdittmar Wisconsin Engines 12 04-10-2019 01:59:40 PM
Wisconsin BKND engine info David LaPell Antique Gas Engine Discussion 5 07-31-2012 03:32:49 PM
wisconsin bknd mag parts Q socal Magnetos, Ignition Coils and Spark Plugs 1 02-16-2012 03:08:24 AM
Wisconsin BKND Almost Finished, Running... KD5BYB Wisconsin Engines 6 05-23-2011 08:33:22 PM
Timing a Wisconsin BKND Outlaw Wisconsin Engines 2 07-11-2009 06:28:00 AM
