Help With Maytag WB Appreciated
this thread has 8 replies and has been viewed 2004 times
Old 06-29-2014, 09:11:30 AM
leegramas leegramas is offline
Unhappy Help With Maytag WB Appreciated
Hello,
I am not sure how to use this site yet. I have a model 92 Maytag that I put together following what I think are the proper procedures. It is getting spark. It fired and almost ran then quit. Still getting spark but not even a hint of firing, even with priming. Checked carburetor setting and also check valve free and clear. Any suggestions would be appreciated.
Thank you,
Lee
Old 06-29-2014, 11:23:14 AM
Default Re: Help w/b appreciated
Quick question, did you remove the stationary side of the points when cleaning all up? If so, you'll need a locator tool to set the points in the proper place and firing at the correct time.
Old 06-29-2014, 01:59:42 PM
Kurt Kocher Kurt Kocher is offline
Check compression. You may have a valve stuck open. Had this happen on other engines. Good Luck.
Old 06-29-2014, 02:24:25 PM
HBurk HBurk is offline
Kurt,
I'll bet that's what it is!
Old 06-30-2014, 12:21:28 AM
Tom S's Avatar
Tom S Tom S is offline
Originally Posted by HBurk View Post
Kurt,
When you find that stuck valve let us know!
Old 06-30-2014, 04:29:27 AM
bsatom bsatom is offline
Default Re: Help With Maytag WB Appreciated
Gotta keep them Maytag 92 valve guides lubricated or they'll hang up the valve stems.....sorry, the devil made me say it.
Old 06-30-2014, 02:06:01 PM
A bunch of comedians! reset the carburetor needle valve stop. Fired up and runs like a wristwatch, Thanks, even to the guys that put valves in 2 strokes.
The Following User Says Thank You to leegramas For This Post:
Old 06-30-2014, 02:11:18 PM
Weezer Weezer is offline
You've been initiated Welcome to the club!
Old 08-31-2014, 02:57:15 PM
Gregg Gregg is offline
Did you take your carb apart and check the air valve, seat, and spring?
Identification Appreciated Dale Teerink Steam Stationary Engines, Traction Engines 16 01-18-2011 12:06:30 AM
You are appreciated Max Thompson Onan Generators 0 04-27-2010 07:23:49 PM
Wico EK Help Appreciated Mike Cannon Magnetos, Ignition Coils and Spark Plugs 1 12-31-2007 07:52:15 PM
Maytag 92, help appreciated! JimS Maytag Engine Collectibles 2 07-24-2006 04:23:57 PM
