IH crank
this thread has 9 replies and has been viewed 1985 times
Old 09-08-2004, 06:49:12 AM
peter
Default IH crank
I picked this up at a yard sale. Can someone identify the engine (or tractor) this IH crank handle was used on. Part number 5758T
The hole is about 1 3/4 inch and that sleve is removable. Someone did a nice nickel weld. I think someone felt some pain in the past.
Old 09-08-2004, 07:14:40 AM
Junkologist
Default Re: IH crank
The crank is for an IHC McCormick Deering type M engine. The 1 1/2 horse engine uses a crank with a 1 1/2" hole. The 1 3/4" hole may be for the 3 horse engine, or the crank is worn some. I don't have a 3 horse engine so I can't say for sure.
Mike
Old 09-08-2004, 07:38:39 AM
John Hammink
Your crank is for a 3 hp M engine. I was just playing in the sun, so I took a shot of some M cranks. 1 1/2 - 3 and 6 hp.
Old 09-08-2004, 08:32:39 AM
peter
you guys are fast! Thanks much for the info
peter
Old 09-08-2004, 10:46:32 AM
Joe Morris
John, No one mentioned the reason for the insert in the crank. It can be reversed in the handle should you want to crank the engine from the "off" or Pulley side which would mean the crank would have to be turned counter clockwise. Joe Morris
Old 09-08-2004, 01:04:42 PM
John Hammink
Joe, that's the purpose of the starting crank sleeve. This way it's possible to start the engine at both sides. Consider of places where the engine has to run only in one direction and the pulley has to be at the ignition side. Through this option, I use one of my six horse cranks to start an engine that runs counter clock wise.
"Sixm" John
Old 09-08-2004, 08:02:23 PM
Joe Morris
John. I was well aware of the reason for the insert. I was just commenting that no one mentioned itor asked why it was in there. It seems to be unique to I H C, cranks . Joe Morris
Old 09-09-2004, 04:25:28 AM
Joseph Musser
John I have a 9759T crank that has an insert with a long throat,about 3 or 4 inches, instead of the reversible one. what was the longer insert needed for?
Old 09-09-2004, 07:01:31 AM
John Hammink
I don't know Joe, the parts book doesn't mention any longer ones. I think someone made it from an original to use it on his pulley side. There're small faced pulleys with a large dia, so you could reach the gib key with the longer crank sleeve.
"Sixm" John
Old 09-09-2004, 09:56:21 PM
Jack Hallaran
Nice looking paint job on that "M" John. Makes mine look like a clunker.
Jack
Onan 6.5 NH will not crank idoscuba Onan Generators 6 12-10-2011 01:16:18 PM
Worn Crank Pin SteamLoco726 Steam Stationary Engines, Traction Engines 13 04-15-2008 10:13:31 AM
Crank I.D? Alex F Antique Gas Engine Discussion 1 01-19-2005 08:33:03 AM
New Way Crank Guard Jack Lester Antique Engine Archives 0 12-11-2003 09:48:12 AM
IHC M 1 1/2 hp Crank Handle M.Smith Antique Engine Archives 1 11-06-2003 09:00:03 PM
