Alpha DeLaval twin question
this thread has 6 replies and has been viewed 1821 times
Old 10-09-2007, 02:16:15 AM
Question Alpha DeLaval twin question
I recently picked up a small 2 cylinder Alpha DeLaval engine. Here is the data plate info: Type D-600, 3.6 HP, S/N VE224---, The Laval Seperater Co, New York / Chicago. I see what apears to be a fuel pump mounted on the 'back' of the engine, and it is not connected. Does anyone know who built this pump, and if diaphrams are available for it? Does any one have any info on this engine? I have run it, br priming the carb, but I would like to run it off a tank. There are several bosses with tapped holes on the engine, does anyone know what was mounted to them? Thanks in advance ,
Old 10-09-2007, 08:10:40 AM
Daniel Dorece's Avatar
Daniel Dorece Daniel Dorece is offline
Default Re: Alpha DeLaval twin question
This is a Stover engine. The fuel pump was probably made by A C or Autolite but I doubt that parts would be available. A new diaphragm can be made from stock that is available thru auto suppliers. I believe a parts or owners manual is available from one of the Smokstak business sponsors.
Iron Wolf
Old 10-09-2007, 04:18:42 PM
Elden DuRand's Avatar
Images: 11
Andrew:
I think this is like yours. Some of them were badged Alpha DeLaval.
http://www.oldengine.org/members/dur...stoverdv2.html
Fuel pump rubberized fabric can be gotten from McMaster.com
Take care - Elden
Old 10-09-2007, 06:56:45 PM
if its an A-C pump then check with the farmall guys.I have used the replacement parts in other engines. usually only the casting is different.
Old 10-11-2007, 01:53:55 AM
Exclamation Re: Alpha DeLaval twin question
Thank you all for the information. The engine is similar to the one Elden has posted, but there are differences. Mine is rated @3.6 HP. The cooling neck at the head has the studs at a 90 degree setting to your pictures, and the studs do double duty: they are cylender head studs as well as holding the gooseneck. The block mounted water connection is also different, as is also the carb. This engine has a hand crank, that engages a set of lugs, cast into the cramk end. Your green color is the same as mine, although my entire engine is green! Our exhaust manifolds are also different.
Old 10-11-2007, 07:47:48 AM
Tom Martin Tom Martin is offline
Email Not Working
Stover made two other two cylinder, radiator cooled engines. According to Wendel's Power in the Past, Vol.III, they built an MV2 and an MV5. On both of these, the flywheel was on the radiator end and it was started from that end. The MV2 was rated at 2-3 HP originally, and re-rated to 3-5 HP later. The MV5 was rated at 3-4 1/2 HP originally and later at 4-6 HP.
Old 10-11-2007, 10:49:05 AM
Redwing Redwing is offline
oh I knew it now, one man was stopped here 2 days ago, he talking to me about his little 2 cylinders with Alpha DeLaval, he telling me nice barn fresh and runs, he wants to sell to me. I was didnt interested in and didnt know what is it until I read this. I might going look at his engine soon.
also MV-2 & 3 and DV's too some photos
http://www.smokstak.com/forum/showth...highlight=dv-2
I has one nice DV-2 with round top radiator. it has without AC fuel pump, some do have or not. also no serial number on mine. not many was made 1 & 2 cylinder stover. also saw one 2 cylinders on ebay about last week.
Alpha Delaval Help Joe Hugh Antique Gas Engine Discussion 1 01-23-2008 10:36:46 PM
Alpha DeLaval dougtorry Antique Gas Engine Discussion 0 01-22-2008 11:20:40 AM
I did it! (Alpha DeLaval) Greg-N-CA Antique Gas Engine Discussion 4 10-05-2007 02:10:08 AM
Alpha DeLaval 1 3/4 HP Stephen Porter Antique Engine Archives 2 09-28-2004 06:07:13 PM
ALPHA DELAVAL MARK MCCORD Antique Engine Archives 0 11-18-2000 02:31:19 PM
