Oil Field Engines
My 30 HP Reid
this thread has 3 replies and has been viewed 3096 times
Old 10-05-2008, 09:42:28 PM
JHFoster JHFoster is offline
Default My 30 HP Reid
A buddy of mine made this for me. He is a little under the weather and mis-named it as a REED. However hope you like it.
http://www.youtube.com/watch?v=QSgoe20rr7Q
The Following 5 Users Say Thank You to JHFoster For This Post:
Old 10-06-2008, 06:28:17 PM
Ray Ethridge's Avatar
Default Re: My 30 HP Reid
Hey, it is a LONG SHAFT 30 hp! Man I gotta get over and see that puppy!
Old 10-08-2008, 01:12:16 PM
Randy L Peterson Randy L Peterson is offline
What kind of Ignition do you have on that Reid.. And where do you have it timed... I have an 8hp Long Shaft running on a Buzz coil but I have it timed about 5 degrees before top dead center.. I think I need to retard the timing to get it to run slower..
RLP
Old 10-08-2008, 05:02:41 PM
Randy, my mag died and I had to put a buzz coil to make it run for the show. I may just keep it on because it runs so good. It is timed about 15 deg.after TDC. Thanks for looking.
Ray, come on over and we will fire her up.
Reid 8 H.P. Fred Van Hook Oil Field Engines & Related Equipment 0 10-04-2007 04:52:50 PM
6 HP Reid D Davis Oil Field Engines & Related Equipment 2 10-03-2007 09:13:57 AM
15 HP Reid Ken Shaw Oil Field Engines & Related Equipment 6 03-19-2006 02:18:11 PM
This is a BIG reid. zach williams Antique Engine Archives 11 04-06-2004 08:22:34 PM
8hp Reid value Bill Klein (Pa.) Antique Engine Archives 1 07-15-2002 09:27:46 AM
