Wisconsin Engines
Wisconsin Type AFH
this thread has 3 replies and has been viewed 1993 times
Old 01-05-2012, 07:26:38 PM
jbo.aermotor jbo.aermotor is offline
Default Wisconsin Type AFH
I just saved a Type AFH Ser. # 243673 3 1/4 bore From Being scraped. What year was it made and what do think it was used for? It has compression. Ben in california
Old 01-06-2012, 08:34:06 AM
KD5BYB's Avatar
KD5BYB KD5BYB is offline
Images: 3
Default Re: Wisconsin Type AFH
Your engine was made in January 1942 per Wisconsin:
http://www.wisconsinmotors.com/support_serial_search/
Hard to say what it was used for - they were put on just about anything and everything in their day. From tractors to cement mixers. One of my AEH's was clearly setup to drive some sort of engine-mounted pump, clutch, or gearbox due to the short length of shaft protruding from the PTO side of the engine.
I've come to really like Wisconsin engines. They were built like tanks with roller-bearing supported cranks and a lot of extra iron when you take a look at the horsepower rating and compare to a modern day engine of the same horsepower.
thanks much,
Ben in Alabama
Old 05-18-2012, 11:30:35 AM
beaudoin45 beaudoin45 is offline
I also have a AFH #259745 putting it In a homemade buggy found the Info stamped on the back of the tag.Also was SF 3 1/4 x 4 trying to find hp. ratingStarts and runs good. Have fun, Gary...
Old 05-18-2012, 12:36:48 PM
Tencubed Tencubed is offline
Look around this site for a lot of Wisconsin engine information.
http://my.att.net/p/s/community.dll?...pid=256080&ck=
Mike
Wisconsin type AC4S 4cyl in line gilpin10t Multi-Cylinder Stationary Engines and Power Units 3 04-01-2011 04:42:04 PM
Wisconsin THD oil type needed for accesory drive. Norsky Wisconsin Engines 2 08-13-2010 02:51:44 PM
Wisconsin type S8D2 or S-8D2 Defess Wisconsin Engines 0 08-23-2009 06:48:08 PM
Wisconsin 9.2hp AENLD Can't figure out distributor type Kirk Crawford Wisconsin Engines 13 03-31-2009 09:53:51 PM
Wisconsin Type AB John F. Antique Engine Archives 0 10-24-1999 08:49:02 PM
