75 h.p.Fairbanks Morse
this thread has 3 replies and has been viewed 1385 times
Old 05-31-2003, 03:59:28 PM
D. Smith
Default 75 h.p.Fairbanks Morse
Need some advice on rod bearing clearnce onthis engine.It has a 6 in.diameter crank journal and we are not too sure what the max. clearnce should be.Thanks Fellows D. Smith p. s. it is a model Y oil engine.
Old 05-31-2003, 09:38:01 PM
Tony Page
Default Re: 75 h.p.Fairbanks Morse
The ideal clearance would be .004 to .006", but as much as .010" would be OK depending on how hard you are going to run it. You can check it with soft lead solder or plastiguage which you can get at the local parts store. Let me know how you cme out. Tony
Old 06-01-2003, 08:05:05 AM
D. Smith
Thanks Tony, I thought 5 to 10 might be ok but was'nt sure. Instruction book 2450D says "crank pin bearing is readily adjustable" but no spects. Guess the old timers just knew stuff like that! Thanks again. D. Smith
Old 06-02-2003, 11:37:11 PM
Rod Gaffrey
Another way to check clearance is to: Crank the piston to TDC, mount a magnetic base dial indicator to the crankcase with the needle resting on the rod bolt, observe needle reading, with both the inspection cover and the valve chest cover removed, insert a bar completely through the engine and pry up on the rod cap, observe the needle deflection, loosen rod bolts and remove necessary shims to obtain the proper clearance, retighten rod bolts and recheck needle deflection. One should not have to remove the cap to do the above operation. A fellow that has worked on these very large Fairbanks engines gave me this advice. Good Luck.
Fairbanks Morse Z thiggy Hit & Miss Gas Engine Discussion 4 03-10-2015 04:09:22 PM
Fairbanks Morse ZD J Mag Help.... Redhookred1 Magnetos, Ignition Coils and Spark Plugs 3 07-10-2014 03:55:27 PM
Fairbanks Morse ZD 2HP Gilbert Armour Hit & Miss Gas Engine Discussion 3 07-05-2014 03:14:59 PM
37 1/2 hp fairbanks Morse 48bomber Hit & Miss Gas Engine Discussion 3 06-25-2014 12:21:59 AM
FB/Morse-Need a Part- Morse Fairbanks Ser# 833745-1942? Babbit? LShap1777 Hit & Miss Gas Engine Discussion 4 09-12-2008 11:03:58 AM
