Go Back   SmokStak > SmokStak® Antique Engine Community > Shows and Swap Meets > Coolspring Pennsylvania
Coolspring Pennsylvania The Coolspring Power Museum contains the largest collection of historically significant, early stationary gas engines in the country, if the not the world. Visit Coolspring, Pennsylvania for the Summer and Fall Expo and Swap Meet!
First weekend down at Coolspring 2015
this thread has 0 replies and has been viewed 2319 times
Old 04-19-2015, 11:48:47 PM
Jonah Close's Avatar
Jonah Close Jonah Close is offline
Default First weekend down at Coolspring 2015
The weather was just perfect for getting things done around the museum this past weekend. I had gotten got some more scraping and priming done on the Windy City building and now just about ready for beginning the final coats of paint and painting the window/door frames. All the painting should be done by the June show. Mike Fouco made some progress on the 50 Hp Flickinger setting up the side shaft and checking for any binding which there was none. That engine is coming together very nicely and he hopes to have it running within the next year given that everything goes together smoothly. I also installed some water traps, one in the main air line coming into the building to hopefully catch the water in the air system before it makes to the engines. The problem was that the water would soak the spark plug upon starting. The other trap is to catch the water before going out to the steam engine. Rod Fielder, the foreman of this operation, began to lay out the rest of the pump jack assembly for the steam engine display out side. We now have just about everything thing we need to start putting things together and completing the pumping display.
I will take some photos of progress on the scraping and painting and post them here when I get back down to the museum in May.
---------- Post added at 11:48 PM ---------- Previous post was at 11:41 PM ----------
The Flickinger with the side shaft temporarily installed.
Coolspring Power Museum 2015 Flame Ignition Expo. Wayne Grenning Antique Gas Engine Discussion 230 07-15-2015 06:08:57 PM
Santa Margarita, Calif Show, Memorial Day Weekend 2015 Tom Madden Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 129 05-28-2015 01:10:22 AM
Coolspring Flame Ignition Show June 2015 Update LCJudge Antique Gas Engine Discussion 0 12-23-2014 12:58:16 PM
Little Casterton Working Weekend 2015 Stephen Watson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 09-25-2014 05:23:54 PM
Coolspring 2015 dates Tanner Remillard Antique Gas Engine Discussion 5 08-18-2014 02:45:31 PM
