Old-Engine Magneto & Ignition Page
this thread has 3 replies and has been viewed 25306 times
Closed Thread
Old 07-09-2015, 12:02:05 PM
Harry's Avatar
Images: 316
Default Old-Engine Magneto & Ignition Page
OLD ENGINE MAGNETOS and IGNITION SYSTEMS
A collective diatribe of tales and tribulations on maintaining a HOT spark in your gas engine ignition with low and high tension coils, ignitors, condensers, magnetos and magnet charging.
Upon restoring my first gas engine, the Witte, I quickly found out that engines don't start and run right unless the ignition is set up properly. Having had a lifetime of electronics experience, I set out to gain as much knowledge as possible about engine ignitions and what keeps them running. This page includes many observations about ignitions and gas engines as you will see when you click your way through the different sections in the table above. This is a rather lengthy "diatribe" and it's therefore split out into the different sections, some long, and some short. It all started with the ignitor, battery and coil, but the Wico high tension mag or the BUZZ COIL are the ones most seen on engines. Don't forget to look at the magnet charger in the Summary section and see other reader's comments in the email section. You may want to visit my Ideal lawnmower engine page for information about magneto tripping mechanisms.
http://www.old-engine.com/magneto.htm
The Following 2 Users Say Thank You to Harry For This Post:
Old 07-09-2015, 12:31:00 PM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: Old-Engine Magneto & Ignition Page
Sweet COOL info thank you harry
Old 10-06-2016, 06:19:23 PM
ddh360 ddh360 is offline
Need some help on my magneto please.
See: https://www.smokstak.com/forum/showthread.php?t=162523
Old 02-11-2018, 04:33:16 PM
allenrhowe allenrhowe is offline
how do i change points on my 1.5 h.p. e j.d. engine
Closed Thread
Magneto Applications/Replacements Page(s) ListerDiesel Magnetos, Ignition Coils and Spark Plugs 7 01-17-2016 06:28:49 PM
K-W Ignition Co Model J magneto isandian Magnetos, Ignition Coils and Spark Plugs 0 07-08-2014 08:00:09 AM
Page magneto help Mike Shaffer Antique Gas Engine Discussion 0 04-28-2014 09:56:01 PM
Villiers MK 10/1 HS Magneto ignition Defess Small Air Cooled Gasoline Engines 2 01-01-2009 06:21:05 AM
Need Expert Magneto / Ignition Help!!! David Sundry Antique Engine Archives 7 04-26-2004 12:08:28 AM
