Jacobson Machine Mfg. Co., Warren, Pennsylvania
this thread has 396 replies and has been viewed 77281 times
Old 03-01-2014, 11:26:45 AM
Don Worley Don Worley is offline
Default Re: Jacobson Machine Mfg. Co., Warren Pa.
I am taking a break from the show pictures. I try to gauge interest in what I post by the thank you responses. No response=not much interest.
Pictures of a advertising card around 1906-1908.
ID:	189371   Click image for larger version
Old 03-01-2014, 06:54:13 PM
Mike Paich Mike Paich is offline
Don thanks for the information and pictures of Jacobson engines I've found them interesting the different styles and models. Trying to appeal to multiple markets farm, commercial, industrial and oilfield at the same time quite a task in the day.
The Following 4 Users Say Thank You to Mike Paich For This Post:
  #303
Old 03-02-2014, 11:40:16 AM
This thread was started to display Jacobson information including advertising and engine serial numbers so connoisseurs of Jacobson engines can become more familiar with the engines and history. There have been over 300 replies. Lets keep it going by submitting info.
Mike; Thanks for your comments.
1. cut of tandem engine
2. set up for throttle engine
Both from C&D book
The R. G. Shiley engine from Warren Pa. also used same type of throttle. Reply if you want to see this engine also.
ID:	189440   Click image for larger version
Old 03-03-2014, 05:07:26 PM
Please post Jacobson info that you have.
1. Two pictures from a photo shoot for advertising.
2. The resulting advertising card 1906-1908
I don't recognize the buildings as from Warren.
ID:	189609   Click image for larger version
Old 03-04-2014, 08:41:04 PM
Possibly the last 3 1/2 hp made in Warren. Doug's 3 1/2 hp has a serial number of 12697 which is a Titusville engine. I have thought that they may have used up Warren tags in Titusville.
The Following 3 Users Say Thank You to Don Worley For This Post:
  #306
Old 03-05-2014, 06:06:56 PM
Bulletin 54
This only measures 6 1/2 by 7 inches opened up.
Probably mid teens
ID:	189836   Click image for larger version
The Following 7 Users Say Thank You to Don Worley For This Post:
  #307
Old 03-07-2014, 08:07:38 AM
Saratoga Springs engine. This would be the same as a large Warren Engine.
The Following 4 Users Say Thank You to Don Worley For This Post:
  #308
Old 03-08-2014, 10:56:42 AM
Jamestown NY paper
  #309
Old 03-08-2014, 05:33:38 PM
Doug Sather Doug Sather is offline
Don: That is hard to read
Old 03-08-2014, 08:43:59 PM
Doug; Did you click it twice to make it bigger?
Old 03-08-2014, 08:46:32 PM
I will have to see it in person
Old 03-09-2014, 11:18:19 AM
Factory photo showing side not seen before.
The Following 8 Users Say Thank You to Don Worley For This Post:
  #313
Old 03-10-2014, 04:43:57 PM
Factory picture-7hp or larger on wagon
The Following 10 Users Say Thank You to Don Worley For This Post:
  #314
Old 03-11-2014, 10:52:25 PM
Large Governor weights for purposes requiring even speed.
ID:	190379   Click image for larger version
The Following 6 Users Say Thank You to Don Worley For This Post:
  #315
Old 03-12-2014, 11:24:49 AM
Don,
Does any of your literature tell how Jacobson engines were painted? Such as what steps they did to finish and paint an engine and what kind of paint they used. In the factory photos they look rather flat, not glossy.
Old 03-12-2014, 12:20:05 PM
They used a thick red lead filler and sanded smooth and then applied a thin maroon topcoat. Most of the engines you see no longer have the thin maroon top coat, thus the flat appearance. If the engine was on a cart the engine was painted a very dark green.
The Following User Says Thank You to Don Worley For This Post:
  #317
Old 03-12-2014, 02:31:13 PM
Jeff Wahl's Avatar
Jeff Wahl Jeff Wahl is offline
I believe that the "photos" in posts 312 and 313 are actually illustrations. I can see a signature in one of them, which leads me to believe it was drawn.
-Jeff
wahlengines.com
The Following User Says Thank You to Jeff Wahl For This Post:
  #318
Old 03-12-2014, 03:17:34 PM
I have got several of this type with the signature. I also have real photos that look the same but without the signature. I said photo just for simplicity. Yes the original photos were doctored or drawn to remove the backround etc. and the signature is who probably did it. The tandem engine pics are one example of photo vs. illustration.
Old 03-13-2014, 04:56:30 PM
Automatic engine
1st is an illustration
2nd is a photo
ID:	190481   Click image for larger version
  #320
Old 03-13-2014, 06:52:02 PM
peter p. adomis peter p. adomis is offline
on the regestry item no2192 jabson engine has a carborator on what I call left hand side. what is the brand (name) of the carborator?
Machine shop in western Pennsylvania? J. Sutter Antique Gas Engine Discussion 3 09-25-2014 09:33:33 PM
THe Little Elgin-RA warren Tom Hartfield Small Air Cooled Gasoline Engines 1 03-05-2012 05:31:18 PM
Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES) Denis Rouleau Antique Gas Engine Discussion 10 06-18-2011 11:15:59 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
