Jacobson Machine Mfg. Co., Warren, Pennsylvania
this thread has 396 replies and has been viewed 77257 times
Old 04-04-2014, 09:33:02 AM
Don Worley Don Worley is offline
Default Re: Jacobson Machine Mfg. Co., Warren Pa.
Done. From a photo.
The Following User Says Thank You to Don Worley For This Post:
Old 04-04-2014, 12:26:53 PM
Denis Rouleau's Avatar
Denis Rouleau Denis Rouleau is offline
Originally Posted by Doug Sather View Post
Don: That is hard to read
Try this version of the same newspaper article.
The Following User Says Thank You to Denis Rouleau For This Post:
  #343
Old 04-05-2014, 11:22:37 AM
Another Jacobson compressor has appeared.
Name:	Stars, Evans H&M, Jaky &  Comp 048.jpg
Old 04-15-2014, 10:39:53 PM
Skid measurements for hopper engines.
The Following 2 Users Say Thank You to Don Worley For This Post:
  #345
Old 05-14-2014, 04:47:22 PM
I have not received data/pictures of Jacobson engines for the registry in a couple of months now, until this morning when I got these from England.
With the return of nicer weather, perhaps now is the time to take pictures of your Jacobson and send them in for the registry.
Thanks!
Denis Rouleau
ID:	195538   Click image for larger version
ID:	195539   Click image for larger version
  #346
Old 05-17-2014, 09:38:46 AM
Recent purchase. Larger engines were made here.
Please keep posting pictures and serial numbers of your Jacobson stuff.
ID:	195756   Click image for larger version
The Following 5 Users Say Thank You to Don Worley For This Post:
  #347
Old 05-27-2014, 02:35:54 AM
Bug1929 Bug1929 is offline
Don, I see that there is Jacobson paint number on the top of the Skid Measurements drawing. That would help a lot of people. Regards from Geoff McCarten.
Old 05-27-2014, 09:25:55 AM
The numbers listed are for a maroon color. It was originally applied as a thin top coat. On most engines it has worn off. The numbers are all auto paint in acrylic enamel.
Old 06-15-2014, 10:12:38 AM
For those of you who are thinking of going to Coolspring this week, I am bringing my 2 1/2 hp Titusville type U sideshaft. Doug Sather is bringing his 3 1/2 hp Titusville SN 12697, and I am showing my 3 1/2 hp Warren engine SN 12696. Bring your Jakes to the show.
Old 06-15-2014, 11:05:07 AM
I'm looking forward to some "fresh" pictures of all these Jakes at Coolspring.
Denis Rouleau
Old 06-15-2014, 05:59:50 PM
Dave Nielsen Dave Nielsen is offline
I am planning on taking my 5hp Jacobson. Don, I have to give you your pattern back for the speed control. Dave
Old 06-15-2014, 10:18:37 PM
Dave; Glad you can make it. That is 4 Jakes so far. I will get pictures of all the Jakes that show up.
  #353
Old 06-28-2014, 09:12:14 PM
Consecutive numbered Jacobsons. The one on the skid is s.n. 12696 tagged Warren Pa., and the one on the cart is s.n. 12697 tagged Titusville Pa. Both are 3 1/2 hp. They were shown at Coolspring. There are videos of them running on other threads.
  #354
Old 06-29-2014, 06:39:13 AM
I do not know how this can be sorted out but I find it impossible to believe that Jacobson #12696 was built in Warren and that their next engine #12697 was built in Titusville, especially when we know that the move from Warren to Titusville was not a planned event, but a rushed event following the burning down of the Jacobson plant of Warren in March 1923.
I also suspect that no Jacobson engines were ever built in Titusville and engine production had more than likely ceased in Warren several years prior to 1923.
Jacobson had already built over 12,000 engines by 1917-1918 and they remained committed to provide parts for the engines already built even though their main field of manufacturing had shifted to other things, namely gears and transmissions. The Titusville operations probably consisted in making replacement parts for Jacobson engines built in Warren several years earlier.
Having said that, I do not doubt that Jacobson #12696 has a Warren tag and Jacobson #12697 has a Titusville tag because I have good clear pictures of both tags.
Here is a theory I have to possibly explain this situation (it is pure speculation on my part and could be completely wrong) but here it is:
Jacobson #12696 and Jacobson #12697 were built the same day in Warren in around 1917 or 1918. When Jacobson #12697 needed parts/repairs in 1923 or 1924, it ended up in Titusville. By then the engine could have lost its original Warren tag and from the serial number stamped on the end of the crankshaft a new tag was put on the engine with the Titusville location on it.
Denis Rouleau
The Following 3 Users Say Thank You to Denis Rouleau For This Post:
  #355
Old 07-09-2014, 06:59:46 AM
SteveK SteveK is offline
Hi Dennis, I have a question regarding some engine tag pictures on your Jacobson registry.
The tag with serial no. ending in 257 is definitely mine. The other tag ending in 271 IS my tag BUT with a different serial no.
No doubt they are both my tags but one is not my serial no.
interesting......
Steve
ID:	199886   Click image for larger version
On the level
Old 07-09-2014, 07:36:26 AM
interesting......
Steve
Hi Steve, here is the explanation:
You are right, both tags are pictures of your engine's tag. One is of the tag on your engine and the other one is for another engine which I had a real poor picture of so I used the picture of your tag as the background with the proper info for the other engine and voila.............2 nice tags for the 2 engines.
Denis Rouleau
Old 07-09-2014, 07:49:28 AM
I thought maybe that was the case. Nice job!
Also if I have not already said it Thank you for organizing this registry, I have since been able to figure my engine is probably a 1916.
Steve
On the level
Old 10-16-2014, 04:17:01 PM
RVandervoort1 RVandervoort1 is offline
Hey Denis and Don,
First off I wanted to say thanks for making this thread into what a wealth of knowledge it is now. I have been following this thread for awhile now and as of last weekend I now have something to contribute. I picked up a 4-1/2hp Jacobson at a sale and have started to dig into it. I will get serial number and other info when I get home. For now here are a few pics. I am sure you will be hearing from me more as I am going to need some info on parts to put it back to original. Thanks again Jay
First is a pic of it at the sale. Second and third are when I got it home.
The Following 7 Users Say Thank You to RVandervoort1 For This Post:
  #359
Old 10-17-2014, 03:31:36 PM
Ok, so here are my tags. Looks worse in the pics than it actually is but is still kinda crappy. Did or does anyone reproduce these? It is engine number 7053, size 5-1/4 x 7, and hp 4-1/2. The little tag selling Jacobson grease and oil is kinda neat. Thanks again Jay
The Following 2 Users Say Thank You to RVandervoort1 For This Post:
  #360
Old 10-17-2014, 07:06:14 PM
Jay, I've added your Jacobson to the Jacobson registry here:
http://buzzcoil.brinkster.net/moody/page101.html
Denis Rouleau
Machine shop in western Pennsylvania? J. Sutter Antique Gas Engine Discussion 3 09-25-2014 09:33:33 PM
THe Little Elgin-RA warren Tom Hartfield Small Air Cooled Gasoline Engines 1 03-05-2012 05:31:18 PM
Jacobson Machine Mfg. Co. Warren, Pennsylvania (PICTURES) Denis Rouleau Antique Gas Engine Discussion 10 06-18-2011 11:15:59 PM
WD-40 IH at J.B. Warren Sale Eric Best Antique Farm Tractors 0 09-23-2005 09:35:45 PM
