Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm + Industrial Antiques and Collectibles > Maytag Engine Collectibles
Maytag runs and hits hard
this thread has 2 replies and has been viewed 709 times
Old 10-24-2018, 12:01:26 PM
46Chief1 46Chief1 is offline
Default Maytag runs and hits hard
Hello guys I have three model 92 engines restored and two of them run great. The third is a 1929 long frame that runs ok but it is a little harder to start and when it runs it hits really hard and is loud when it hits. Every time the muffler pops it is loud. Is this the timeing ?
Old 10-24-2018, 12:22:33 PM
Default Re: Maytag runs and hits hard
I was going to say, timing, that's about all I can think of. It sounds like it may be a bit too advanced.
Old 10-24-2018, 03:15:04 PM
Points gap correct? Should be .020", plug gap .025. If set too close, timing wil be advanced. If the points mount plate has shifted, then it needs to be re-set. Contact Mark Shulaw, and send him your mag mount assembly (Plate and all. he can set it properly. Not quite a job you can do at home. He is here on the Stak
D4 5T CAT Runs Great but HARD TO START Burt Lade Dozers and Crawlers 9 09-20-2018 01:33:53 PM
McCormick-Deering M hard to start... runs like a top Wildirishtime Antique Gas Engine Discussion 20 12-24-2015 04:36:32 PM
ONAN 7.5JB Propane, Hard Starting, Runs Poorly DuaTJC Onan Generators 11 09-17-2013 06:20:44 PM
Maytag 92 - hits more often as it warms up KD5BYB Maytag Engine Collectibles 11 03-10-2012 08:37:43 AM
Maytag 92 Hits every cycle of flywheel Bigjoedo Maytag Engine Collectibles 14 05-21-2011 08:36:12 PM
