Help Identify Tester
this thread has 7 replies and has been viewed 2461 times
Old 10-26-2010, 11:25:33 AM
Tom Martin Tom Martin is offline
Email Not Working
Default Help Identify Tester
I have picked up a tester that is labeled as a King Type T3. I am attaching some pictures of it. It appears to be a coil and condenser tester, but has a connection for a vacuum line and has a vacuum gauge. I don't understand the purpose of the vacuum parts. It has a knob that controls a variable spark gap, a place to connect the primary of a coil, a place to connect the high tension lead and a place to connect a condenser. Does anyone have any info on this tester or maybe some instructions for it? I haven't tried to use it yet as I don't have a 6v battery.
ID:	91051   Click image for larger version
ID:	91052   Click image for larger version
ID:	91053   Click image for larger version
Old 10-26-2010, 12:41:39 PM
xplor xplor is offline
Default Re: Help Identify Tester
King was a brand name of test equipment in 1935.
They made SPARK PLUG TESTERS; CONDENSER TESTERS; MOTOR AND IGNITION TESTERS; COMBINATION COIL AND CONDENSER TESTERS; IGNITION COIL TESTERS; ARMATURE TESTERS; IGNITION COIL PREHEATERS USED IN CONNECTION WITH IGNITION COIL TESTERS; SUPPRESSOR TESTERS; GENERATOR, STARTER, CUT-OUT, AND VOLTAGE REGULATOR TEST UNITS; TEST STANDS FOR TESTING AUTOMOBILE ENGINES; VACUUM AND COMPRESSION GAUGES FOR USE IN ENGINE TESTING. http://www.trademarkia.com/king-71362021.html
Very good find.
The Following User Says Thank You to xplor For This Post:
Old 10-28-2010, 03:51:50 PM
Dempster Dempster is offline
Never seen a King tester that old nor have any info on it. Maybe someone will have info on it later. Unfortunately can tell you King tester company as we knew them for years shut down and is no more. Another company in California bought them out only to change and keep making the distributor test stands but they seem to have no interest in helping to service the rest of old King testers was my experience talking to them recently. King made all kinds of testers over the years for other companies too having other names on them. It may have more value to a historical collector now than for actual use.
http://www.4king.com/
The Following User Says Thank You to Dempster For This Post:
Old 10-28-2010, 04:37:48 PM
bocephus_k6 bocephus_k6 is offline
I have one just like it my grandfather used many years ago in his service garage, also have its big brother I think is a tad newer, its blue and orange I believe.
Brian
The Following User Says Thank You to bocephus_k6 For This Post:
Old 10-29-2010, 10:13:14 AM
Email Not Working
Thanks for the replies and info. Can anyone tell me what the purpose of the vacuum portion was? I could understand if it was for distributor testing, but this instrument seems to be only for testing coils and condensers.
Old 10-29-2010, 11:48:44 AM
A vacuum gauge is useful in setting timing and testing the vacuum advance on distributors.
Old 03-09-2018, 01:37:29 PM
ctbill2010 ctbill2010 is offline
I have a KING tester ser. # 740 110v 60 cy. 6vdc condenser / coil / ignition tester. It works but I would like to find some instructions for it. Any one out their with a copy? Thanks Bill Muska wmuska@sbcglobal.net
Old 03-10-2018, 12:56:18 AM
cobbadog cobbadog is offline
I agree that the vacuum is for testing the advance and retard for the distributor.
I have just purchased a coil/condensor tester but it looks nothing like this one does. After a lot of help through this site I did get the answers needed to be able to operate it.
400 HZ load tester J. Fischer Military MEP and Aircraft Gen-Sets 1 04-29-2009 07:03:09 AM
New sparkplug tester help Chris Page Magnetos, Ignition Coils and Spark Plugs 7 02-11-2009 11:13:49 PM
Is this some kind of tester? Steve Kunz Magnetos, Ignition Coils and Spark Plugs 15 11-19-2008 01:37:52 AM
mag coil tester larry harding Antique Engine Archives 1 10-16-2000 01:00:51 AM
Re: CURRENT TESTER Russ Hughes Antique Engine Archives 11 07-15-2000 01:31:59 AM
