A Root & Vandervoort 1HP - ½ scale engine
this thread has 3 replies and has been viewed 1945 times
Old 06-22-2011, 10:19:20 PM
Default A Root & Vandervoort 1HP - ½ scale engine
was found on a guy’s trailer fender at the Coolspring, Pa. show on the “LAST” day? It looked OK, complete, dry, and with little compression. He said he builds models, gets them running and then puts them on the shelf. It was covered in brass debris from grinding other brass parts in the shop. He wanted X $’s, but was open to offers so I did just that. Well you know the story, “OH, I can’t do that”. So, I bumped the offer by a hundred, and then another hundred before he said “OK”. I paid for it and grabbed it by the flywheel and walked away. I cleaned the filings and old oil off it at our Coolspring spot and boxed it up for the ride home. I got it running at home and the compression came right up after oiling. The latch arm against the gear was ground away to much and the latch finger was a good ½” away from the catch and a good ¼” play when latched up (clank-clankety-clank) . I got the torch and braze rod out and built up the boss about ¼” and ground it to fit. I dug out a used hacksaw blade (I save a lot of stuff) and made a new latch finger to fit. I now have about a 1/16” play for both latch clearances . It still needs a few “MINOR” adjustments to get it the way I want it. I’m going to replace the extended all rod with “CUSTOM” made bolts with brass acorn nuts making it “LOOK EVEN BETTER” . I contacted Rocky's Model Shop and for $10 am getting a full set of plans for the model. The Coolspring, Pa. show was a lot of fun, but I still am having fun in the shop, even in NJ where it’s going to rain for the next day or so.
ID:	109115   Click image for larger version
ID:	109116   Click image for larger version
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 06-27-2011, 06:35:26 PM
Default Re: A Root & Vandervoort 1HP - ½ scale engine
I had (TOOK ) time today to fuss with the model. Put some Coleman fuel in the tank, choked it and got it running. Not bad for what it is . I still need to tinker and play with it some more to get it the way I want it to run. BUT, for now, it’s OK . Here is a Youtube video of it running .
The Following 10 Users Say Thank You to Paul Spence For This Post:
Old 06-30-2011, 07:18:27 AM
All I can say is WOW!! I order the drawings for the model last week from Rocky's Model Shop http://home.earthlink.net/~randyarockwell/index.html, and they showed up in Wednesdays mail.
I sure got more than expected from Randy. THANKS .
Old 06-30-2011, 12:15:02 PM
Dennis K. Nash Dennis K. Nash is offline
Beautiful! I was at a show on the last day. A man had a very nice model engine he was reducing the price on. I still had to tell him no, I couldn't afford the models, I had to buy the real ones.
The Following User Says Thank You to Dennis K. Nash For This Post:
Root & Vandervoort 5/16 Scale Model of 4HP Horizontal, any videos? Don Siefker Hit & Miss Gas Engine Discussion 2 01-14-2011 04:11:08 PM
Root & Vandervoort 5/16 Scale Model of 4HP Horizontal tank cooled, any videos? Don Siefker Scale Model Engineering 3 01-01-2010 09:37:15 PM
Root & VanDervoort Engine Register OzEngines Hit & Miss Gas Engine Discussion 0 08-17-2007 07:49:50 AM
Root-Vandervoort hoist engine Schramm Hit & Miss Gas Engine Discussion 1 01-30-2006 04:36:31 AM
Root & Vandervoort engine Bob Johnson Antique Engine Archives 2 07-31-2002 11:18:33 PM
