Steam Engines
Houston, Stanwood & Gamble
this thread has 11 replies and has been viewed 2971 times
Old 01-29-2013, 04:47:16 PM
DavidRaines DavidRaines is offline
Default Houston, Stanwood & Gamble
Ran across a stationary steam engine in mid Missouri that was made by The Houston, Stanwood & Gamble Co., Cincinnati.
Has a 54" x 13" flywheel/pulley with a gardner governor.
Still sitting where it has since 1917.
Got a couple pictures with my IPAD but don't know how to upload from it yet. Will be seeing it again in a couple weeks so will take the digital camera and a good light.
I'm not a steamer guy so are these common engines?
Thanks.......Dave
Old 01-29-2013, 10:56:54 PM
Mike McKnight Mike McKnight is offline
Smile Re: Houston, Stanwood & Gamble
Thanks.......Dave
Extremely common. Still would be worth saving though, if it could be had reasonable.
The Following User Says Thank You to Mike McKnight For This Post:
Old 01-30-2013, 11:37:14 AM
Pete LaBelle Pete LaBelle is offline
Default Re: Houston, Stanwood & Gamble
Can you e-mail the picures from your Ipad to yourself ?
Ask a neighbor kid. They'll tell you how.
Looking forward to some pictures. Like was said before, any steam engine is worth saving.
Pete
Old 01-30-2013, 02:06:31 PM
PTraubert PTraubert is offline
eMail NOT Working
I saved a 12X16 side crank HSG engine from an East Texas sawmill site back in 2000. A lot of work for an engine that was all used up.
It was, I believe, well built with on notable exception. The crosshead wrist pin was clamped in the crosshead by a bolted split in the casting. Crosshead was broken at some pont in its operation and the piston let loose and busted out the cylinder head.
I went to a North Carolina auction around 2002 where there was a large 2cyl HSG with both crossheads busted in the same way. Cannot remember if the cylinders were damaged or not.
At any rate, any steam engine is worth preserving if at all possible.
Patrick
Old 01-30-2013, 02:48:25 PM
Sorry for the poor pictures as the engine is in a corner surrounded by some racks and the Ipad doesn't have a flash(at least I don't think it does).
It is sitting where it always has for ump-teen years.
Dave
ID:	156538   Click image for larger version
The Following 6 Users Say Thank You to DavidRaines For This Post:
Old 01-30-2013, 03:55:10 PM
Jeff Smith Jeff Smith is offline
Like Mike McKnight, I have a soft spot for the stationary engines and I would drag that engine home.
Jeff
The Following User Says Thank You to Jeff Smith For This Post:
Old 01-30-2013, 04:49:15 PM
gleaner gleaner is offline
I have one just like it, also originated in Missouri. All steam engines in this day and age are worth saving. Get it dealt for and haul it home. It will be easy to set up as both crankshaft bearings are in the base casting so you won't have to set up an outboard bearing like other larger sized stationary engines.
Old 01-30-2013, 11:45:40 PM
Reeves13hp's Avatar
Reeves13hp Reeves13hp is offline
David
Glad to see the steam bug has bit you!!! that will look good with your
gas engine collection. let me know if you need help.
David jowett
Old 01-31-2013, 02:10:57 PM
eMail NOT Working
Yes, get it if at all possible. The self-contained ones are so much better than the outboard bearing kind. If you get a bore and stroke I may be able to come up with some catalog information.
Patrick
Old 02-07-2013, 12:59:40 PM
Patrick, the best I can determine, the stroke is 14.5 ". Don't know how to determine the bore. It is very hard to turn over. got it to move a little with another guys help.
Got a couple pics of the engine with my camera but can't upload til I get home.
The owner says he doesn't want to sell as long as he is alive.
Dave
The Following 2 Users Say Thank You to DavidRaines For This Post:
Old 02-07-2013, 03:10:09 PM
eMail NOT Working
According to my undated catalog, these engines were a "Class A" designed for up to 100psig steam.
Based on your nominal 14" stroke, it crosses to a #28 10" X 14" engine rated at 35-40HP, 54" X 12" flywheel, 3700# engine weight.
Patrick
The Following User Says Thank You to PTraubert For This Post:
Old 07-15-2019, 01:40:38 AM
RPC14801 RPC14801 is offline
I know this post is a few years old... I’ve licked up an old HSG steam engine, 12x16 cylinder. Missing the connecting rod and the crank side main bearing cap. Is there another out there someone could get pictures of the rod and some dimensions s I can make one? And possibly use the cap as a pattern for a new one...thanks
Gamble Skogmo Masteride mower wheelhorseboy Garden Tractors and Mowers 3 12-01-2011 10:00:44 AM
Gamble Skogmo tiller info needed wheelhorseboy Garden Tractors and Mowers 2 06-22-2011 12:03:29 AM
Look What Followed Me Home From Houston MS BDePriest Hit & Miss Gas Engine Discussion 3 05-18-2009 03:27:02 AM
Gamble's Coronado JoeC6 Small Air Cooled Gasoline Engines 2 05-12-2009 12:06:24 AM
Houston Stanwood & Gamble WALTER Antique Engine Archives 1 02-09-2001 01:04:19 AM
