Nelson Bros. Little Jumbo
this thread has 9 replies and has been viewed 2461 times
Old 03-23-2001, 06:39:30 AM
Bob Naske
Default Nelson Bros. Little Jumbo
This engine is Webster fired, Model P 1 3/4hp,paddle style rocker arm. Whatever is supposed to pull exhaust rod back is missing. Manual shows exh. LEVER return spring- separate from exh. VALVE spring but it is not clear where it goes. I am assuming it fits over exh. valve spring & sits into outer area of paddle- pushing from cyl. head to paddle.Is this correct?And is correct spring available anywhere?
Old 03-23-2001, 08:45:33 AM
Ted Brookover Ted Brookover is offline
Default Re: Nelson Bros. Little Jumbo
You Got it right Bob, but I have never seen repro Springs offered anywhere, I would check with Ed at Hit & Miss first though.
Old 03-23-2001, 08:51:11 AM
mike otis
bob you are right on where the spring goes. I don't think anybody has one listed. If I remember right I used the spring out of a 60's GM car starter solenoid.
Old 03-25-2001, 05:59:04 PM
Tim B
I hope this picture helps. This is a Monarch made be Nelson brothers, should be the same.
Good luck, Tim B
Old 03-25-2001, 08:34:58 PM
mike otis
i have a 7hp manarch just like it
Old 03-26-2001, 11:20:06 AM
Tim B
Hey Mike,what you said about the spring out of a solenoid sounded great. I went to the garage and tried it but it was too big so I figured that your Nelson was bigger.
Old 03-26-2001, 05:01:50 PM
Bob Naske
How about one of you fellas that has an I-H "M". I've been told, but haven't seen one, that they have a similar setup.I have been rootin' around the local farm equip. dealers & may have come up with something, but I don't know it's original use.
Old 03-26-2001, 06:15:24 PM
mike otis
Tim It's been close to 30 years since i used one but it was a 1 and3/4. I had a couple of early 60's gm cars at that time and took one out of one of them. as i remember the spring was a little lighter but it worked.
Old 03-26-2001, 08:57:32 PM
Joe Morris
Bob, The I.H.C. engines had a spring that wrapped around the rocker arm in the center to keep one end of the arm snug against either the valve stem or the push rod, sold all my M,s so don't remember which. I guess you would say it kept the slack out. This is not the same as the Nelson Bros engines spring in question.
Old 03-27-2001, 11:41:58 PM
Steve Royster
Bob, This is the same as my Nelson Bro engine. Big return spring actually coils into valve spring at head and into paddle on arm. I
Nelson Bros. Little Jumbo Michael Smallridge Hit & Miss Gas Engine Discussion 11 06-14-2019 11:43:58 AM
little Jumbo Nelson Bros Mark Gross Hit & Miss Gas Engine Discussion 9 02-14-2015 06:23:58 PM
Nelson Bros. Jumbo ?'s Mike Smith Hit & Miss Gas Engine Discussion 3 12-10-2005 02:19:00 PM
Nelson Bros. Little Jumbo Mark K Antique Engine Archives 1 11-15-2004 01:08:14 PM
Nelson Bros.Jumbo Pollack Pete Antique Engine Archives 2 07-07-2001 12:59:38 AM
